C63 AMG (W204) 2008 - 2015
oil temp
Old 04-25-2014, 07:45 AM
D7reU's Avatar
C63
oil temp
Hey guys,
What oil temperature does yours usually read?
Old 04-25-2014, 08:15 AM
Ingenieur's Avatar
C63 AMG
this has at least 1000 posts
just search 'oil temperature'
https://mbworld.org/forums/search.php?searchid=13320902
Old 04-27-2014, 01:36 AM
HoustonC63's Avatar
2013 C63
Mine runs in the 220s but tonight it was actually at 248 as I get it 4k rpms for about 30 minutes as I was zipping around the freeway.
Old 04-28-2014, 09:34 AM
Dogtag114's Avatar
2009 c63
Originally Posted by D7reU
Hey guys,
215 F... steady
Old 04-28-2014, 09:43 AM
Mort's Avatar
Mine is pretty steady 102C (215F) with normal driving. It will go up quite quickly if you start to drive hard and keep the revs up.
Old 04-28-2014, 09:55 AM
jmueller's Avatar
Jag F-Type V8
Holds steady at 220 here in South Florida on my 35mph commute to work.
Old 04-28-2014, 12:20 PM
zibby43's Avatar
'20 GLC300 SUV
212-214 degrees Fahrenheit, on average.
Old 04-28-2014, 07:14 PM
shades's Avatar
09 C63, 11 Cayenne S
Mine use to stay at 98°c but now it goes pretty high ...like 112 regular driving. I think my oil cooler fan crapped out or the fuse is blown. Gotta look into this as it got me concerned, because this is regular driving in c mode....I can't imagine in m mode
Old 04-28-2014, 07:32 PM
stratman's Avatar
2022 4 Runner Pro, supercharged and lifted Lime Rush, 2018 E63s wagon Edition 1
I put my reading in the speedo gauge to AMG and the oil temp. was 221 at stop and go (with air temp of about 72 F and about 510 miles on the car) and the coolant was at 199 and both dropped after moving again. At about 80 mph the oil was at 215 and the coolant was at 197. As a side note, I found that the oil level was at about half full after a good drive versus about 1/8 above add once it was cold. Really does make a difference when the measurement is taken. All in all the C63 is an AWSOME machine! OORAH!
Old 06-27-2020, 08:24 PM
jm6001's Avatar
CLS55 IWC
Well in honor of oil talk I might as well make a sideways shift to oil additives 😂😂
Ceratec by lubri moly anyone? Input?
Old 06-27-2020, 08:48 PM
BLKROKT's Avatar
Received 2,810 Likes on 1,664 Posts
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
How about doing a little bit of work to find one of the thirteen thousand threads discussing those additives and posting there instead of this stupidity
Old 06-27-2020, 09:22 PM
jm6001's Avatar
CLS55 IWC
I sense some inner anger and tbh you don't need to enter the thread and post anything if your not interested or grumpy.
​​​​​Sorry to ruin your day.
Old 06-28-2020, 12:11 AM
Jasonoff's Avatar
Received 1,572 Likes on 925 Posts
2010 C63 AMG
Is lubri moly a knock off brand?
Old 06-29-2020, 02:56 AM
Rick X Joaquim's Avatar
C63
Your oil doesn’t look out of range.
I noticed that the oil temp runs cooler with air con on. If you have been driving with air con off and the ambient temp has increased over your spring time, that might explain why your oil temp is raised.
Old 06-29-2020, 03:04 AM
G_Money's Avatar
'04 E55 (Gone but not forgotten), '13 C63 P31 (RIP), another '13 C63 PP
Sure, you can find it at KMart!
Old 07-01-2020, 10:23 PM
go team's Avatar
2012 C63, GL63, 1989 300CE
Just put 0w30 or 5w30 and call it a day
Old 07-02-2020, 04:23 PM
SPONSOR
hachiroku's Avatar
2007 Mercedes E63 AMG
i believe lubri moly is the same brand marketed to a different region. it least that is what i've seen. could be wrong though. just stick with liquimoly if possible is my recommendation.
__________________
-BARRY
​​​Follow us on instagram @eightysixtuned
https://www.eightysixtuned.com
Quick Reply: oil temp
