P2626 and P0559
P2626 and P0559
Ive been having rough idle issues, throttle lag and got a CEL. P2626 I've had before, I will change the passenger upstream O2 sensor, but I also had a code P0559
Brake Booster Pressure Sensor Circuit Intermittent?
- Faulty Brake Booster Pressure Sensor
- Brake Booster Pressure Sensor harness is open or shorted
- Brake Booster Pressure Sensor circuit poor electrical connection
Brake booster pressure sensor is connected to brake booster by a hose. It detects brake booster pressure and sends the voltage signal to the Engine Control Module (ECM). The sensor uses a silicon diaphragm which is sensitive to the change in pressure. As the pressure increases, the voltage rises.
Read more: http://engine-codes.com/p0559.html#ixzz306uhE8cc
Anyone know where this sensor is or if I could pick one up online. I stopped driving the car but the brakes were working fine.
