Wheel Spacers
W204 C63 Coupe, W166 ML350 BlueTEC, 928GT, C5 Z06 & IS300 race cars, EQE 4Matic+ on order
You want hub-centric H&R spacers, 12mm front & 10mm rear and longer bolts (40mm - and you'll probably need to shave down the rears by about 2-3mm). You should be OK w/ no rubbing if you're running OEM tire sizes. Read the thread suggested above by Mort.
