C63 AMG (W204) 2008 - 2015
Anyone else 3rd to 4th gear slip before engagement?
Old 05-12-2014, 08:29 PM
AMG Boost's Avatar
2010 C63 P30
Shifting in my 2010 C63 from 3rd to 4th it does not seem to engage into 4th right away. What happens is it shifts to 4th, the RPM goes up maybe 300-400rpm and then it will engage the gear and drop the rpm down. It is almost like the clutch is slipping. This only happens to me in C or S mode with about 30-50% throttle. The more throttle seems to make it slip more before it engages...
I took my car into the dealer today and had them look at it and I documented this possible issue to protect myself.
Anyone else have this?? Im not to worried about it, the car drives fine. Was just curious.
Old 05-12-2014, 08:35 PM
Autosport7's Avatar
C63 AMG
I could be wrong but I believe there is a transmission software upgrade that is free if charge at your local dealer that should take care of that.
Old 05-29-2014, 12:52 PM
AMG Boost's Avatar
2010 C63 P30
Thanks for reply.
I will check with my dealer about the transmission software.
Anyone else experience this? It happens to my car every time it shifts now from 3rd to 4th. More throttle the more slip it creates. I might post up a video of it later.
Old 05-29-2014, 12:58 PM
Merc63's Avatar
C63 AMG
Reset your tranny adaptation.
Old 05-29-2014, 12:59 PM
AMG Boost's Avatar
2010 C63 P30
How can I go about doing that? Take to the dealer?
Old 05-29-2014, 01:18 PM
whoover's Avatar
'19 E63S sedan
Yes. Resetting the adaptation will be the first thing they try. If that doesn't work, a repair is in order. If you're still on warranty, don't delay. Slippage often indicates a new transmission.
You want any needed work to be done before the warranty expires. Reporting it is not enough unless you want to get lawyers involved.
Old 05-29-2014, 01:37 PM
AMG Boost's Avatar
2010 C63 P30
Thanks for reply
I will go to the dealer and show them this again and hopefully a tranny reset will fix it.
I noticed today it does slip at WOT also when it shifts to 4th.
Anyway thanks
Old 05-29-2014, 02:29 PM
jvanbrecht's Avatar
2017 Mini Cooper S Clubman ALL4 - British Racing Green
You will probably want to reach out to your tuner and have the car returned to stock before you go to the dealer.
This will be an instance where they will deny warranty claim as a tune can and does directly affect the transmission.
Old 05-29-2014, 02:48 PM
AMG Boost's Avatar
2010 C63 P30
Old 05-31-2014, 11:02 PM
AMG Boost's Avatar
2010 C63 P30
Video. What do you guys think? Il be working for the next couple weeks so no time to visit dealer but thought I would post a vid.
This is about 30-40ish% throttle just cruising. Sport mode.
https://www.youtube.com/watch?v=GExq...ature=youtu.be
Old 05-31-2014, 11:45 PM
Merc63's Avatar
C63 AMG
Is that a part throttle shift or wot?
Are you in Edmonton?
It would only slip under full throttle. If you do lots of burnouts while shifting gears, that will cook the clutches in a hurry.
If that's part throttle you need to reset adaption.
That doesn't look like slip to me. Mine was slipping with the blower when it wasn't built. Id go wot and shift into third or fourth and it would redline and the car wouldn't move.
Old 05-31-2014, 11:49 PM
AMG Boost's Avatar
2010 C63 P30
That doesn't look like slip to me. Mine was slipping with the blower when it wasn't built. Is go wot and shift into third or fourth and it was redline almost and the car wouldn't move.
Yeah thats part throttle. about 30-40% throttle.
No im in Calgary (Go flames)
Yes at WOT it does not "slip" per say. Once the 4th gear is in, it holds the power no problem.
I am also leaning toward this being a software issue.
Old 06-01-2014, 12:20 AM
Merc63's Avatar
C63 AMG
That's an adaption issue. It has learned something.
Old 06-01-2014, 01:48 AM
snowmuch's Avatar
C63 AMG
Calgary!! Let me know if they actually have it available. I think dealers in Calgary is restarted, they don't even know how to do a COMMAND software update...
Old 06-01-2014, 02:47 AM
whoover's Avatar
'19 E63S sedan
It seems like more than software to me. Like I said, the first thing they will try is the 3-4 adaptation, but that much slippage probably means an actuator or a clutch is worn. They will also look for codes and at the magnets in the oil pan to see how much debris is present.
If the adaptation fixes it great, but you need to let the dealer do whatever it needs. That's real slippage and it generally gets worse fast.
Old 06-01-2014, 05:06 PM
roadtalontsi's Avatar
10 C six trizzle
valve body or clutch problem. adaptations wont fix that. mine sort of does that 2-3 at full throttle but i have a supercharger. Im replacing the clutches next week
Old 06-01-2014, 10:56 PM
jvanbrecht's Avatar
Are you replacing them, or having them replaced.
Old 06-01-2014, 11:00 PM
10 C six trizzle
I'm = I AM. you can call me billy.... billy badass. I'll take some pics
Old 06-01-2014, 11:57 PM
Merc63's Avatar
C63 AMG
Are you using an upgraded clutch pack with more friction area or stock?
Valve body tune?
Old 06-02-2014, 01:59 AM
whoover's Avatar
'19 E63S sedan
Valve body tune?
We might be confusing two kinds of clutches. Slippage can be one of the three one-way clutch elements that work with the brake elements (bands) to select a gear. Then there's the lock-up clutch in the old transmission or MCT clutch pack in the new transmission. They can both result in slipping but just one upshift sounds more like a clutch element or its actuator.
Old 06-02-2014, 09:23 AM
jvanbrecht's Avatar
Yes take pics
Mine has been slipping for a while here and there, and on 2 separate occasions (even though the dealer found nothing wrong and did nothing), I hit the gas and the car did not move and bounced off the red line. Yes the car was in gear and not neutral.
Car is now out of warranty
Old 06-02-2014, 11:12 PM
AMG Boost's Avatar
2010 C63 P30
So I put the car back to stock just now. My "slip" problem is not at bad as it is with a tune. Very weird. The slip is still there stock but it is about 50% less slipping. I use eurocharged V5 by the way.
Il keep you guys updated when I get this fixed.
Old 06-03-2014, 12:21 AM
10 C six trizzle
ill be replacing the K1 clutch pack at the minimum. Once I finally get it torn apart i'll see what else is crapped out. Fluid is only 2k miles old and smells a little crispy. Valve body is going to get sent off while the car is down. Been slammed with other stuff but atleast got the valve body off. With any luck ill get the motor and trans out tomorrow.
Old 06-03-2014, 01:46 AM
whoover's Avatar
'19 E63S sedan
Sounds like the K2 clutch pack. It's engaged for 4th through 7th. If it's tired, it will take longer to get into 4th but won't affect any other shift. Less torque without the tune makes it easier for it to bite.
Of course it could be the solenoid (in the valve body) that actuates it. But worn clutch disks are the most straightforward cause.
Old 06-03-2014, 01:53 AM
604 C63's Avatar
2012 E550 Cabrio
That aint right. There is no way that is an adaptation issue. Take it in. Do not pass go, and I am sorry to say..... do not collect $200. Seriously though, that seems like the kind of thing that gets worse before it gets better so better head 'er.
Quick Reply: Anyone else 3rd to 4th gear slip before engagement?
