C63 AMG (W204) 2008 - 2015
Kleeman Large Throttle System
Old 05-30-2014, 08:54 AM
RawBenz's Avatar
AMG
Has anyone done this mod?
What gains?
Is it really beneficial because it's close to $4000
Old 05-30-2014, 09:47 AM
mr747's Avatar
c63
Subscribed
Old 05-30-2014, 11:48 AM
ruey220's Avatar
ml55, Ml63, Porsche, C63S ED1
if you're looking into it you might as well check out renntech's. looks like they are larger by 2mm on kleemanns.
Old 05-30-2014, 11:58 AM
SmittyAMG's Avatar
2009 C63 AMG & 2015 Lexus RX350
Right off Kleenann's website.
63-K1: A sophisticated new ECU software. Up to 540 HP and 650 Nm (481 lb-ft) of torque.
63-K2: K1 + a set of long-tube exhaust manifolds (front cat delete system, LHD cars only). Up to 575 HP and 720 Nm (533 lb-ft) of torque.
63-K3: K2 + a large throttle system and a set of hi-flow air filters. Up to 590 HP and 730 Nm (541 lb-ft) of torque.
Based on this, with high flow air filters, it adds 15HP if headers are already installed and you are using a tune from them (maybe others?)
Old 05-30-2014, 03:14 PM
Kriston's Avatar
C63 AMG
Upgraded throttles will not just yield higher HP, your throttle response will improve as well.
For the price, I would stick with Long tubes + Tune and be done with it.
Old 05-30-2014, 05:28 PM
johnnyblaze's Avatar
CLS63S
11 crank horsepower for $4,000?
Sign me up!
Old 05-30-2014, 07:30 PM
RawBenz's Avatar
AMG
If installed will I need a retune?
Old 05-30-2014, 08:22 PM
ruey220's Avatar
Sign me up!
get it from the one who buys it for $4k and figures out his car doesn't end up faster than an SLS and sells it for $2k.
Old 05-31-2014, 12:07 AM
roadtalontsi's Avatar
10 C six trizzle
it's probably the sls intake manifold
Old 05-31-2014, 07:28 AM
Maverick1975's Avatar
Vath ML63 Brabus C63 SL63 CLK63BS C63BS
I defy anyone to feel 15hp difference. Just get your tuner to get existing throttle bodies to open to their maximum and save the cash. Guys on this forum including myself have been asking dyno proof of any of these gains from Kleeman for years and nothing has been produced. Just get forced induction
Old 05-31-2014, 10:44 AM
whoover's Avatar
'19 E63S sedan
I don't understand the theory behind this mod. On the supercharged S55, etc., the throttle body was a limitation. It was worthwhile to increase the stock 74mm throat to 82 mm, as many tuners did.
But the M156 has dual 70 mm throats. That's 46% more area than even the 82 mm throat on the modded version of the engine this replaced. How is that going to be a limiting factor?
Dual 70's already flow more than the engine can use so what's the point of dual 82's?
Old 05-31-2014, 10:47 AM
Merc63's Avatar
C63 AMG
Throttle plates don't even open all the way. I haven't confirmed this on just a tune car, but on the blower cars, they open to 87%.
I think this is the same on tunes too? Maybe someone can confirm.
Old 06-01-2014, 04:17 AM
Southways's Avatar
C63 Coupe, 2014, 507
<snip>
Except at WOT, a well designed throttle body should have the same modulation/response as OE. The feeling of better responsiveness will often come from the progressive ramps being removed which simply yields more air at less pedal position, typically making the car harder to drive smoothly. Kinda like changing the cam profile on a cable TB.
Are you actually measuring the plate position or reading the TPS? In many (most) OE ECU's the displayed TPS angle ("Absolute TPS") reported through the CAN-bus to the OBDII is truncated pre-90 degrees. The PID of "ETC Position" is more likely to be the true angle, however that may not always be able to be interrogated.
For something to consider ...
At 87% it may be WOT. The seat angle will typically be ~5 degrees and if seat is zero, then WOT is 85. Or, if seat is set at 5 and 90 is WOT, the "shadow" of the shaft will probably be more than 3 degrees so it is unlikely to have any more flow at 90 than 87.
Old 06-01-2014, 10:46 AM
Merc63's Avatar
C63 AMG
Idle is 14%, wot is 87% according to absolute throttle position via odb.
Quick Reply: Kleeman Large Throttle System
