h&r coilovers
Yes they are adjustable, however the rears are no easy task. The fronts are adjusted by simply removing the wheel and then turning the lock rings to either raise or lower. The rears have a separate shock from the spring assembly. The spring assembly sits inside a suspension cup right next to the wheels and because of the way the adjustment rings are positioned you have to remove the whole spring assembly in order to adjust them.
