C63 AMG (W204) 2008 - 2015
Weistec Engineering Oil/Air Separator Group Buy 2014
Old 06-03-2014, 03:37 AM
Exhibit13's Avatar
2010 c63 (p31) w/LSD
Originally Posted by m a x i m u s
btw, after installing the catch can, how does one clean out oil that has already made it's way into the engine due to this?
That was my point, on my car the "damage" is done. So does this really make sense at 36,000mi?
Old 06-03-2014, 04:06 AM
SCAMG13's Avatar
2013 C63 coupe P31
+Ar0c,nkc, and myself.
1.)avery.whss
2.)bjonesmd
3.)kfriedenberger
4.) Maroonc63
5.)Tex5
6.)507AMG
7.)Mort
8.) Andy0331
9.) sinape62
10.) chchart
11.) shades
12.) kgmuse
13.) -Lightning-
14.) 8o8is
15.) zibby43
16.) OlegKouz
17.) Ar0c
18.) nkc
19.) SCAMG13
__________________
Old 06-03-2014, 04:29 AM
CPD SLK's Avatar
2009 C63 AMG
1.)avery.whss
2.)bjonesmd
3.)kfriedenberger
4.) Maroonc63
5.)Tex5
6.)507AMG
7.)Mort
8.) Andy0331
9.) sinape62
10.) chchart
11.) shades
12.) kgmuse
13.) -Lightning-
14.) 8o8is
15.) zibby43
16.) OlegKouz
17.) Ar0c
18.) nkc
19.) SCAMG13
20.) CPD SLK
Old 06-03-2014, 05:14 AM
Tex5's Avatar
CLK 63 AMG Black Series, A45 AMG
Originally Posted by CPD SLK
1.)avery.whss
2.)bjonesmd
3.)kfriedenberger
4.) Maroonc63
5.)Tex5
6.)507AMG
7.)Mort
8.) Andy0331
9.) sinape62
10.) chchart
11.) shades
12.) kgmuse
13.) -Lightning-
14.) 8o8is
15.) zibby43
16.) OlegKouz
17.) Ar0c
18.) nkc
19.) SCAMG13
20.) CPD SLK
Another one for me
21.) Tex5
Old 06-03-2014, 07:31 AM
Autosport7's Avatar
C63 AMG
I was just about to place myself back on the list until I read your question. This is a good question. Can we get an answer to this? I assume the catch can will prohibit additional oil from entering, but any oil currently in there will remain there until it is physically removed.
Old 06-03-2014, 07:51 AM
dolfandrus's Avatar
14 e63s
+1
Old 06-03-2014, 08:07 AM
  #32
-Lightning-'s Avatar
c63 coupe PP
The intake has to be taken off, like in the pics weistec posted. You will keep further oil from getting in though.
Old 06-03-2014, 09:07 AM
  #33
bjonesmd's Avatar
'14 507, '05 F-150, 1992 Ducati 900SS, 2000 Ducati ST2, Trek Fuel 98
I would agree that you would want to get this as early as possible in the engines life, however there are likely two points that make adding it a good idea at any time.
First, as Weistec states, the aeresolized oil is a low octane addition to the intake gases and effectively reduces the octane rating of the intake charge. The engine's knock sensors would, I presume, retard timing and reduce power to prevent pre-detonation.
Secondly, even though there may be accumulated oil in the intake tract, that does not mean adding more can't do any further harm in the way of valve and piston deposits.
For me the real question is not "do I add this to my engine?"
It is "Why is an equivalent component not already there?"
I don't believe it is because MB doesn't care about the longevity of their engines. I suspect it is because the cost/benefit ratio of this additional component is marginal when applied to millions of units. That is, if they get 1 more year of life before a rebuild, on an engine that is designed to run say 12 years on average before requiring a rebuild (just a guess on my part), there is no significant benefit to MB as a motor company to add this component and extend the life of the engine for year or two. It is not the type of component that will prevent a catastrophic failure e.g. head bolts. It only keeps the engine cleaner over time and likely marginally improves power and emissions.
I will get one because I am compulsive about my automotive care and keeping my engine as clean as is reasonably possible sounds very good to me. Plus it's CNC gear head coolness.
Old 06-03-2014, 09:40 AM
  #34
shades's Avatar
09 C63, 11 Cayenne S
To add to that, you could always get an engine clean which in turn will clean your valves of deposits. We have a machine that will clean your valves, combustion chamber, o2 sensors etc... I usually do this to my engine every six months for just this reason. Having the catch can will further help my engine as bjonesmd has mentioned. It's good piece of mind for me
Old 06-03-2014, 04:06 PM
  #35
jrcart's Avatar
2008 CLK63 Black Series 2012 C63 Black Series 2014 SLS Black Series
I see where you are comng from with your question but this is slightly skewed logic. If you have a crack in a dam and some water gets through do you just throw your hands up and say the hell with it or do you repair the damn before it gets worse? A high milage engine that has had a lifetime of oil crankcase blowby might benefit from this mod even moreso than a low mile car, ever heard the term "straw that broke the camels back"? It's possibly even more important for you to get the problem under control now and prolong the life of your engine...better late than never. Every M156 engine will benefit from this catch can no matter if it has 100 miles on it or 100,000 miles on it. On my CLK BS I was buring over a quart of oil every 1000 miles or so, that oil was venting into my airbox, some of it sat in my airboxes but some of it worked it's way through my MAF's and into my engine. After installing the catch can I was amazed at how much oil was being "caught". Weistec should just post a video of how much oil works it's way into a catch can after just 500-1000 miles and I guarantee they would sell out in 24hrs. It's never too early or late to add this catch can mod. AMG should have had a better fix for this from the factory. I have regular conversations with a few people from AMG and even they acknowledge(off the record) that they engine blowby on the M156 is an pretty big issue and they were happy to see this Weistec aftermarket solution.
...as for the $400 price, that is an absolute steal! I get "special' pricing from Weistec and that is lower than I paid for the catch can when they first introduced it a couple years ago so you would be a fool not to jump at this opportunity.
Old 06-03-2014, 04:28 PM
  #36
m a x i m u s's Avatar
C63 AMG P30 *EuroCharged*| Porsche Cayenne | Buell XB9SX
1.)avery.whss
2.)bjonesmd
3.)kfriedenberger
4.) Maroonc63
5.)Tex5
6.)507AMG
7.)Mort
8.) Andy0331
9.) sinape62
10.) chchart
11.) shades
12.) kgmuse
13.) -Lightning-
14.) 8o8is
15.) zibby43
16.) OlegKouz
17.) Ar0c
18.) nkc
19.) SCAMG13
20.) CPD SLK
Another one for me
21.) Tex5
22.) m a x i m u s
Old 06-03-2014, 04:32 PM
  #37
Rate's Avatar
MY12 C63 P/P
1.)avery.whss
2.)bjonesmd
3.)kfriedenberger
4.) Maroonc63
5.)Tex5
6.)507AMG
7.)Mort
8.) Andy0331
9.) sinape62
10.) chchart
11.) shades
12.) kgmuse
13.) -Lightning-
14.) 8o8is
15.) zibby43
16.) OlegKouz
17.) Ar0c
18.) nkc
19.) SCAMG13
20.) CPD SLK
21.) Tex5
22.) m a x i m u s
23.) Rate
Old 06-03-2014, 05:27 PM
  #38
the_indian_kid's Avatar
2008 MB C350 4MATIC/2011 CL63 AMG/2014 C63 Coupe 507
1.)avery.whss
2.)bjonesmd
3.)kfriedenberger
4.) Maroonc63
5.)Tex5
6.)507AMG
7.)Mort
8.) Andy0331
9.) sinape62
10.) chchart
11.) shades
12.) kgmuse
13.) -Lightning-
14.) 8o8is
15.) zibby43
16.) OlegKouz
17.) Ar0c
18.) nkc
19.) SCAMG13
20.) CPD SLK
21.) Tex5
22.) m a x i m u s
23.) Rate
24.) the_indian_kid
Old 06-03-2014, 05:56 PM
  #39
johnnyblaze's Avatar
CLS63S
1.)avery.whss
2.)bjonesmd
3.)kfriedenberger
4.) Maroonc63
5.)Tex5
6.)507AMG
7.)Mort
8.) Andy0331
9.) sinape62
10.) chchart
11.) shades
12.) kgmuse
13.) -Lightning-
14.) 8o8is
15.) zibby43
16.) OlegKouz
17.) Ar0c
18.) nkc
19.) SCAMG13
20.) CPD SLK
21.) Tex5
22.) m a x i m u s
23.) Rate
24.) the_indian_kid
25.) johnnyblaze
Old 06-04-2014, 02:53 AM
  #40
awasak17's Avatar
2012 c63
I would like to get in on this aswell! Count me in!
Old 06-04-2014, 03:16 AM
  #41
AMG893's Avatar
2010 C63 Estate
Shipping price to Sydney, Australia?
Old 06-04-2014, 08:55 AM
  #42
507AMG's Avatar
2017 C63S Coupe
That's 25! Let us Pay. Also, since this good size group is predominately W204 chassis both coupe and sedan will a prefab mounting bracket come with this unit?
Old 06-04-2014, 09:13 AM
  #43
Jasonoff's Avatar
Received 1,576 Likes on 929 Posts
2010 C63 AMG
The clean air will eventually flush it all out over time.
Old 06-04-2014, 09:14 AM
  #44
Kriston's Avatar
C63 AMG
I assume this is a fairly straight forward DIY.
Wesitec any install instructions that you can post up?
Im in as well!
Old 06-04-2014, 11:36 AM
  #45
Former Vendor of MBWorld
Weistec's Avatar
Weistec
Although the question seems to be answered, we will hit it one more time.
The M156/M159 engine is prone to getting oil in the intake system due to the design of the PCV system. Crankcase ventilation routing from the engine block to the intake manifold is in close proximity to the front timing chain, and this causes oil to be sucked up into the intake manifold. Although AMG took a very different (and very nice) approach to venting the crankcase, these engines do suck up quite a bit of oil, causing the intake manifold, runners, valves, etc. to be coated with oil.
From our testing, and years of examining these engines, the oil does eventually burn away and dry off if no new oil has entered the system. To answer the question, "Is the damage already done", the answer is no. Run the separator and over time you will see that 90% of the oil is not in the intake manifold.
We hope this helps. Thanks!
Weistec Engineering
Old 06-04-2014, 11:38 AM
  #46
Weistec's Avatar
Weistec
Here is a short video a customer put up on YouTube. This is a great representation of how much oil the separator will not allow to go back into the engine.
Old 06-04-2014, 11:40 AM
  #47
Weistec's Avatar
Weistec
One more...
Installation manual link below. Thank you all!
http://weistec.com/install/m156oas.pdf
Weistec Engineering
Old 06-04-2014, 12:56 PM
  #48
nkc
nkc's Avatar
2012 C63 Coupe P31 CF Trim - Eurocharged V7, 2012 RangeRover Autobiography, 2017 GLS 63 Amg
how do we proceed to buy one? still showing up on ur site as sold out
Old 06-04-2014, 01:40 PM
  #49
glennhl's Avatar
2011 C63
Can more than 25 participate? I'd like to get one also.
Thanks,
Glenn
Old 06-04-2014, 02:21 PM
  #50
Weistec's Avatar
Weistec
We will allow the group by to run until Friday the 13th!
Weistec Engineering
Quick Reply: Weistec Engineering Oil/Air Separator Group Buy 2014
