C63 AMG (W204) 2008 - 2015
What material are the cylinder walls?
Old 06-20-2014, 02:42 PM
alpha26's Avatar
GTR R35 1300whp, C63 Weistec stage 3
What material are the cylinder walls on M156 engine ? Niscali ?
Thank you
Old 06-20-2014, 03:20 PM
bhamg's Avatar
C63 AMG
The original brochures which I still have state that the cylinder bores are sprayed with twin-wire-arc-spray coating - TWAS - process, creating a very hard (twice as hard as steel), low friction surface.
Old 06-20-2014, 03:39 PM
Ingenieur's Avatar
C63 AMG
One brochure 'plasma sprayed to a mirrored finish'
Another 'micropore'
Same one twin-wire arc sprayed coating
Some sort of metallic vapor deposition process
Old 06-20-2014, 03:43 PM
Ingenieur's Avatar
C63 AMG
The cylinder bores themselves are also unique. The M156 is world's first production engine to feature cylinder bores with twin-wire-arc-spray (TWAS) coating. TWAS is a new process that creates a very low friction surface, which is twice as hard as conventional steel. The application involves using water at high pressure to roughen the cylinder walls. Afterwards, high voltage is run through two metal wires, which begin to melt. An atomized gas is then used to spray the metal particles from the meted wires on to the cylinder walls. Afterwards, the cylinders are honed.
Old 06-20-2014, 03:48 PM
Ingenieur's Avatar
C63 AMG
Good article
http://m.americanmachinist.com/uncat...gine-cylinders
Old 06-20-2014, 03:54 PM
Ingenieur's Avatar
C63 AMG
Page 21
http://www.n2m-moveo.com/PDF/TRIBOLO...hel_BORDES.pdf
Old 06-20-2014, 04:25 PM
bhamg's Avatar
C63 AMG
Originally Posted by Ingenieur
Good find. This is why I've asked several times here - can one hone these cylinder walls w/o compromising the longevity of the bores - or does it just not need to be done during say, a piston replacement? I presume the surface is not silicon-etched prior to TWAS.
Old 06-20-2014, 06:02 PM
alpha26's Avatar
Thanks guys for reply !!!
Old 06-20-2014, 06:11 PM
Ingenieur's Avatar
C63 AMG
The treatment layer is pretty thin I would guess (it may be in the document)
Fractions of a 1000th
Are the factory bores prep'ed or raw?
Honed, cross hatched, scruffed, whatever
I would say any machining may be out of the question
Shop manual would say for sure
As would who ever does the rebuilds for AMG's remfged program for replacement engines after a headbolt lets loose lol
My Bosch book may have some detailsbut it's at work
Old 06-20-2014, 07:02 PM
whoover's Avatar
'19 E63S sedan
The layer is .1 to .15 mm or 4 to 6 mils. Not a lot to hone.
http://technicity.daimler.com/en/nan...omment-page-1/
Old 06-20-2014, 07:08 PM
whoover's Avatar
'19 E63S sedan
The whole point of the technology is to produce a mirror-like surface to reduce friction. No scuffing!
http://www.motorauthority.com/news/1...on-engine-tech
Old 06-20-2014, 07:18 PM
Ingenieur's Avatar
C63 AMG
Looks polished almost
http://i1.ytimg.com/vi/ri_LFckaT7g/sddefault.jpg
Old 06-20-2014, 07:30 PM
whoover's Avatar
'19 E63S sedan
More than almost polished.
Old 06-20-2014, 07:57 PM
bhamg's Avatar
C63 AMG
Duplicate.
bhamg's Avatar
C63 AMG
That is amazing! No wonder I've never heard honing mentioned when M156 pistons are replaced.
Quick Reply: What material are the cylinder walls?
