Best Air Filter, AirBox, Air Intake
My C63 is an 09 and currently the airbox/intake/filters are all stock.
I see a lot of people on here have ROW airboxes, AFE filters, carbon fiber intake etc.
I was wondering what the best combination would be from all your experiences? Any combination that will give the engine better sound quality?
Not 100% certain about this, but wouldn't be surprised if it were true...
Another thread on here somewhere asked if the K&N filter were the same as the Weistec or AFE...
The difference is really that K&N oils theirs, take that red oil off and the filters look identical. I wouldn't be surprised if K&N manufactures for the other guys and stamps their names on the product for resale.
Regardless, I am running K&N's but feel there is no difference in filters.
Where the debate really lies is in the intake system.
Many have claimed hp gins from the CF style intakes, those claims are typically shot down pretty quickly by consumers leaving vendors struggling to stand behind their products proving otherwise. Most agree that the gain from these intakes is from the upgraded filter while installing the CF style intake.
I am currently running the ROW's with K&N's that is an automatic charcoal filter delete. I personally don't think my butt dyno is tuned well enough to pick up on any of the gains, if any are present, but I am happy with the products I have installed. I have not received any CEL's thus far and it has changed the sound in a positive manner according to my taste.
Hope this helps in some way. A lot of non-proven facts in and around this topic. My guess is AMG built an incredible intake system that is more than sufficient for the 156 and is hard to top. I would be willing to bet installing filters is all you need to do to squeeze a few more unnoticeable hp out of the car.
Afe filters
ok ok, abcut973 is a baller as well, confused myself as you (abcut973) have the Renntech tune, not intake.
Fellas the Renntech intake makes 10 Wheel HP.
FYI I just did the V5 tune I put down 440 WHP and 380 WTQ. (Read: 525 HP and 460 FT TQ at the crank) with my bolt on's. This is also on a low reading Dyno Dynamics machine, on Dynojets you can add 8-10% more HP. Dyno file attached.
I had the car re-dyno'd. Using Eurocharged Dyno. The first Dyno I went to, was not calibrated correctly. Thus the higher reading.
My baseline on the Eurocharged Dyno was 390 WHP and 355ish TQ prior to uploading the V5 file.
So a net gain of 50WHP and 25TQ. Take a look at the dyno sheet and you will see the gains from the baseline.
This is why Dyno's shouldn't be taken as an end all. They all read differently. But im confident in the Eurocharge Dyno reading. From what I understand Eurocharged Canada stated its one of if not the most powerful C63 they have tuned without headers.
With headers I'm sure I can surpass 500 WHP and 420 TQ.
Received 2,810 Likes
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
I've been thinking about making a custom intake for my C63. The problem with our intake is the filter area, and no airbox or filter mod will yield much gain. We need to increase the filter size, as well as the pipes into the throttle body - particularly the "Y". This thread shows pretty close to what I'll do, pending room constraints I'll look to put big cone filters close to the grille opening or behind the headlights. https://mbworld.org/forums/c32-amg-c...i-c55-amg.html
Or this: https://mbworld.org/forums/w211-amg/...tem-m113k.html
Has anyone in the C63 world constructed something like this? It should be pretty straightforward to fab this up - just a "Y", and two bends of 3" pipe. And there should be pretty significant gains as well.
I would like to see something like that
Jr cart I think has a customs intake on his sls
2011 C63 AW
I never understood the reasoning behind buying an aftermarket air filter or air intake other than to blow money on something and convince yourself you got a performance gain.
MAF sensors and ecu control the amount of air going into the engine, constantly regulating it. If you increase the amount of air flow available without a tune, why would you expect a performance gain? It will only suck what the computer tells it to suck regardless of how much it COULD suck.
What am I missing here?
ECU or "Computer" - The ECU is similar to that of a brain in the human body. Yes it tells the rest of the car how to operate, but if the pathway is restricted, or not working to its fullest potential, it leaves room for improvement. By improving the amount of air that can be introduced to the system and the easier that air is obtained, the better. The brain is only telling the system when to breathe and as long as the MAF isn't finding TOO much air, then the system should accept the amount being introduced. If the filter flows more freely, then more air should be inhaled as the car isn't working any harder to gain restricted air than it is to inhale more flowable air. It will always inhale at the same rate...
Not sure if this is 100% accurate, but this is how I understand it.
our cars are drive by wire and the ecu will trim the TB's
the primary input is your foot though
filter/intakes can provide marginal gains by lowering pumping losses
for a given rate of acceleration you need X torque
to produce that torque some is lost as parasitic losses, one of which is pumping air through the engine...if the intake restriction is lowered, ie, filter DP, those losses are smaller...so more net power available for accel, or reduced throttle position for the same accel
this can improve efficiency a bit also under normal operation
You guys are trying to fix something that isn't broken. The stock system is more than adequate for an N/A application. Heck weistec even uses row boxes up to stage 3... What does that tell you? The intake on the m156 is not the culprit of hindering power. Go jack up the car and look at the manifolds which are pathetic and on top of that the 500-600 cell primaries cats are the problem.... Not to mention the 400-500 cell sec cats. This cars exhaust is choked up! The amount of money you would spend to make a proper custom intake would be insane. And, what would be the point of all this air coming in on if your still running stock exhaust? If your gonna open up the intake. Do it right and open up the exhaust as well or just leave it stock if your gonna do a Mickey Mouse setup.
Solo wing (08-05-2021)
I will say this: I put K&N in my RS4
picked up 7-8 HP as dyno proven by European Car magazine
picked up 1 mpg average
a little more noise
saved some money cleaning vs new paper
some environmental benefit: less crap in landfills
but I agree, no big power gains and stock is more than adequate
a little more noise
Spend the money on a proper exhaust system/headers and supercharger instead.
So I guess I'm wondering what the spectrum is on HP/tq gains for more modest to more widespread exhaust mods? Thanks for the input
