C63 AMG (W204) 2008 - 2015
C63 Ticking noise upon light accleration..
Old 07-11-2014, 09:41 AM
ms_
ms_'s Avatar
C63 AMG
Hi,
Recently just traded in my A45 AMG for a C63 coupe with p31 pack and let me say i absolutely love it and do not regret leaving the A class.
One thing which is bothering me is on slight acceleration, say from take off until around 3500RPM ( then motor becomes louder masking the sound ) there is a sight ticking noise which is only apparent on acceleration. Ticking noise is not apparent when slowing down to a stop or even free reving in neutral.
I also notice a slight miss-fire when idling, which i can feel through the steering wheel, or maybe this is normal with a v8 firing order? Not sure..
Any help would be great!
Thanks in advance.
Old 07-11-2014, 10:11 AM
Ingenieur's Avatar
C63 AMG
engine check light?
any codes?
if not I would say no issues
Old 07-11-2014, 02:55 PM
ms_
ms_'s Avatar
C63 AMG
No engine light (yet), is there a way to check for stored fault codes??
Moe
Old 07-11-2014, 03:02 PM
Ingenieur's Avatar
C63 AMG
You need a scan tool
Maybe stale gas
Run the tank low and top off with good feash fuel
See if that helps
If it was misfiring, ping'ing or detonating you would get a light
Old 07-11-2014, 03:11 PM
ms_
ms_'s Avatar
C63 AMG
Hmm okay..
I have had several tanks of fuel through it, using 98+ octane ( in Australia, it's the top stuff at the pump ).
I will book it into the dealer and see how we go! Thanks for the input
Old 07-11-2014, 06:08 PM
Rolf de Graaff's Avatar
C 63 AMG PP
Does the ticking come from the rear?
I have a P30 which also ticks under light acceleration, I thought maybe it had to do something with engaging/disengaging of the lsd??
I also noticed the "misfiring" but was told that everything was okay, maybe I wasn't used to this kind of V8
Old 07-11-2014, 07:11 PM
ms_
ms_'s Avatar
C63 AMG
I wish i could find where the noise is coming from!! Although mine doesn't have the LSD option so not sure about that..
Hmm, best practice would be to jump in another and see if it does the same!
Old 07-11-2014, 10:05 PM
average joe's Avatar
C63 Weistec Supercharged
I had a miss-fire just at idle and just felt like a shudder through the car every now and then. No CEL and no codes, and no change in performance.
I changed the plugs out and that cured the fault.
Old 07-11-2014, 10:23 PM
Ingenieur's Avatar
C63 AMG
A V8 is not inherently balanced
There are resultant forces (and harmonics thereof) that are unchecked
Makes the engine feel like it's misfiring, not 'smooth', 'wobbles'
They can balance most of it out but must pick a freq range
They pick the torque and power peaks not idle
An inline 6 IS inherently balanced
No resultant uncancelled forces
Smooth as a turbine
Any combustion engine engineering text details this for all configurations
V12, v4, etc
Usually up to 3rd order harmonics
After that they are diminished to where they are not an issue
Quick Reply: C63 Ticking noise upon light accleration..
