C63 AMG (W204) 2008 - 2015
help...my car feels "off"
Old 08-08-2014, 09:21 AM
RL1
RL1's Avatar
AMG C63 Affalterbach Edition
So i went away on a small trip (5 days) and left my car at home. When i got back, it felt off. By that i mean that i am running a Eurocharged V5 tune and it feels like the car is back to stock (or worse). In manual mode the downshifts are not as aggressive and i feel like the upshift warning light is coming up sooner and more often (usually i am used to the shift points and can upshift without the warning) and not matched with the acceleration i am used to).
could this be a problem with the tune? transmission? engine??? what are the symptoms of a blown transmission or a shot cylinder?
thanks!
RL
Old 08-08-2014, 10:06 AM
Jasonoff's Avatar
Received 1,572 Likes on 925 Posts
2010 C63 AMG
I've had the upshift warning pop up early (say 6krpm) a couple times now with V5.
Old 08-08-2014, 11:58 AM
PanzerLehr's Avatar
2014 C63
Can you flash back to stock, drive a bit and reflash the tune? Just an idea. I had a (extremely heavily modded) VW that when I went away for a week or two at a time it always ran like garbage when I would return. I reset all electronic anything and after a few cycles it ran normal. Dunno if it will help you or these vehicles.
Old 08-08-2014, 12:05 PM
avery.whss's Avatar
S550 on order
the ECU basically went back to grandma mode...take it out for a few days and beat on it
Old 08-08-2014, 12:19 PM
SPONSOR
loungn14's Avatar
Location: Houston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
Eurocharged Performance ML63 and TT lambo
unplug the battery overnight and try it
Old 08-08-2014, 12:36 PM
m a x i m u s's Avatar
C63 AMG P30 *EuroCharged*| Porsche Cayenne | Buell XB9SX
that's weird. that happens with the car just parked?
Old 08-08-2014, 12:42 PM
abcut973's Avatar
'12 C63 Black Series, '12 ML350 BlueTech
If you had any cylinder failure or such yo would have all sort of CEL popping up !!!
So my guess is your ECU went dormant !lol!
As others mentioned I would reset TCU/unplug battery and drive it hard for a few miles and see what's happening.
Old 08-08-2014, 12:49 PM
RL1
RL1's Avatar
thanks..will unplugging the battery or doing that process to reset the ECU affect my Eurocharged tune?
I have the MyGenius but only have the V3 loaded on it...didnt have time to put the V5 on the handheld.
BTW, i called the dealer and they said there are over 400 sensors on our car so if it was something major like engine or transmission related i would most likely have gotten an error message.
RL
Old 08-08-2014, 12:54 PM
abcut973's Avatar
It will more likely reset how the ECU/TCU learns your driving habits ( like TB % and such) not put your tune back to stock unless you do so with the handheld. I would recommend you to load your V5 as well to your handhel device just in case.
Old 08-08-2014, 01:03 PM
RL1
RL1's Avatar
thanks..yeah it is a bit complicated to load the V5 tune right now..my home computer is down and i cant install ANY (and i mean ANY) software on my work computer without going through our tech dept thanks to their security protocols..
Old 08-08-2014, 01:22 PM
VaclavSV's Avatar
2012 C63 AMG Black Series
Just turn the Traction OFF and drive the snot out of it -Its a pretty simple fix. The battery is on cycles anyways so just drive it hard and it will come back to life.
Old 08-08-2014, 02:54 PM
Girard@ACGautomotive's Avatar
a car
Bingo.
Old 08-08-2014, 05:47 PM
-Marlin-'s Avatar
2011 C63 AW
She missed you and now she's making you pay....
Typical woman
Old 08-08-2014, 06:22 PM
CarHopper's Avatar
E63S | X5
Haha I love AMG form advice...
Help, car is slow and broken...
Any CELS?
Nope
Go beat the chit out of it.
Old 08-08-2014, 06:30 PM
PanzerLehr's Avatar
2014 C63
Haha it's awesome advice. It normally works!
Old 08-08-2014, 10:33 PM
SROC276's Avatar
2010 C63 P31 AMG
Man, I am going thru the same thing....no punch at all after 3-7k rpm...car sat the dealer getting buckets changed out for 5-6 day. Amg tech reset adaptations and car is way slower than before. Will try battery pull
Old 08-08-2014, 10:37 PM
abcut973's Avatar
Hopefully he did not overwrite your ECU tune .
I hate having my car at the dealership and not knowing what they do to it. Particularly the dealership in my area. I haven't been impressed by their service and knowledge!
Old 08-08-2014, 10:44 PM
chrisridebike8's Avatar
'10 C63
The shift light will come on as you approach redline or any time it feels the tires are spinning too much. See what happens if you turn the traction control off of even to sport. Maybe reload the tune. Could be that you are just engaging the traction control...
Old 08-08-2014, 10:52 PM
SROC276's Avatar
2010 C63 P31 AMG
No my guys pretty good and managed to get all the work done under warranty lol....he owns a modded e55 so doubt ecu was cleared....it felt faster with traction off vs on so it maybe traction control stepping in when I try to punch it....I'll do battery pull and let it learn again.
Quick Reply: help...my car feels "off"
