C63 AMG (W204) 2008 - 2015
Would 2 intake filters take place of charcoal? P0171 CEL.
Old 08-17-2014, 10:22 PM
C63BLUE's Avatar
C63
So my car is throwing a P0171 code every 10-50 miles and seems to have a slight stumble at idle (I'll get to stoplight, it'll stumble/vibrate for a few seconds then go away -- RPM holds constant the whole time).
Car does have ROW air boxes with charcoals removed and AFE dry filters. My question is if the intake is what's causing the lean code, would layering on a stock filter do the trick? I don't have the old charcoals so would it make sense that the new dry filter would act like charcoal, and then a paper filter on top would make it like stock?
What are your thoughts?
Old 08-18-2014, 08:15 AM
Mort's Avatar
I am not sure if that will solve your problem but I don't think it will be possible to get a second filter in the filter box anyway.
Old 08-18-2014, 09:26 AM
jmueller's Avatar
Jag F-Type V8
Agreed. The standard air filters are about twice as thick as the charcoals so I doubt they would fit. You'd also be starving the engine of air. I'm sure you have done this, but have you tried uninstalling the airboxes and re-installing everything to ensure you have a tight seal?
Old 08-18-2014, 09:50 AM
S14roller's Avatar
M3
Wrong post
Old 08-18-2014, 03:46 PM
Vash's Avatar
C63 coupe P31, '11 G37s, '12 RR Evoque Prestige '10 QX56
Could be the intake manifold gasket.
How long have you had the ROW's/aFe's installed? Cel right after install?
You don't have your charcoals, but do you have the old air boxes and filters? If so, see if reinstalling them gets rid of the cel. Swap your stock filters for aFe's (in stock air boxes), drive cel free for a week or so, throw the ROW's back in.
Old 08-18-2014, 03:50 PM
C63BLUE's Avatar
C63
Fair enough, when I opened them, there seemed to be enough room to layer something on top since stock pics always seems like the charcoal and where the AFE filter sits now is about the same size, but I could be wrong.
Yes, took them out, reseated them, and made sure everything was buttoned up tight.
Car drove for about 100 miles with them no problems, and it’s possible I’m getting the code from bad gas (coincidentally, CEL came on after filling up). I’m going to run through the rest of the tank and refuel with some fuel injector cleaner and my usual station and see if that does it.
Was just starting to plan my plan B if gas wasn’t the issue. Don't have the stock filters or box, but hoping it's the gas.
Old 08-18-2014, 04:01 PM
Autosport7's Avatar
C63 AMG
Don't you just need this:
http://www.partsgeek.com/gbproducts/...SygaAgg78P8HAQ
Old 08-18-2014, 04:34 PM
chrisridebike8's Avatar
'10 C63
^^^nah that looks like the cabin filter. That's for the climate control and HVAC
Old 08-18-2014, 05:32 PM
abcut973's Avatar
'12 C63 Black Series, '12 ML350 BlueTech
You probably have a leak somewhere.
I would try different scenarios:
- reinstall OEM boxes + charcoal + OEM filters, clear code and drive for a while,
- No CEL? Then swap filters with AFE, drive,
- No CEL? Then swap boxes with OEM filters and drive,
- No CEL? Then put back the AFE + ROW
If you have CEL (same code) in all cases you have my friend a vacuum leak (intake manifold gasket, pcv valve)
As well if you don;t get any codes for fuel pressure regulator or gas cap the refuelling you did is just a coincidence.
GL
Old 08-24-2014, 08:29 AM
sinape62's Avatar
2013 C63 Coupe
When I first put in my ROW boxes, I noticed the (right box facing the engine from the front bumper) corner nearest to the MAF, I (very slightly) pinched the airfilter. It was the stock filter so I could see a bit of orange gasket visible... I took it apart and reseated it. Also before I loosened the clamps I put an alignment mark as I wasn't sure if there is a torque value for the clamps. Anyway, I got not CELs. I'll have to do this all over again after I receive my dry filters from Weistec.
Old 08-24-2014, 03:31 PM
AMGPower88's Avatar
C63 AMG
So everyone who installs ROW air boxes and AFE filters who get a code? Or is it just because it wasnt installed right?
Old 08-25-2014, 03:19 PM
edwardsflight33's Avatar
'16 CLS 63 S
I installed ROW airboxes and the AFE pro dry s and haven't seen a single code. That was 5k miles ago.
Old 08-25-2014, 06:20 PM
tfthach13's Avatar
'09 C63
I think some MY are more prone to CELs. I think the trend was the 2010+ had no problems, but 2009 and lower had problems with the slightest mods.
Old 08-25-2014, 06:50 PM
SaphGreyC63's Avatar
2012 C63 AMG Sedan
Make sure everything is seated and sealed correctly.
Installed AFE filters the other day, its been about a week, no codes.
Old 08-25-2014, 07:21 PM
-Marlin-'s Avatar
2011 C63 AW
wrong thread
Quick Reply: Would 2 intake filters take place of charcoal? P0171 CEL.
