C63 AMG (W204) 2008 - 2015
Vossen Vfs 2 Wheel question
Old 08-19-2014, 03:07 PM
shivsiddh's Avatar
2012 C63 Amg
2012 C63 Coupe (Black)
Trying to understand what size will fit on this car. Not an expert at all and pretty much really confused so any help will be appreciated.
I am interested in the Vossen VFS 2's in either Satin Bronze or Graphite.
Now they only make 20" and 22".
Will 20" wheels fit on this car? 20x9" for front and 20x10" in the rear....
Is anyone running a similar set up? or better yet, does anyone have VFS 2's on their car? What wheels, what tire size and what offset.
Thanks!
Old 08-19-2014, 03:15 PM
olszowa12's Avatar
'08 C63 Estate
They will fit but 20" in monoblock design look very big on a C63. Especially if the car is not lowered.
I would only run 20" if the wheel had a step lip.
Old 08-19-2014, 03:20 PM
shivsiddh's Avatar
2012 C63 Amg
They have it on the c63 black series and i thought it looked awesome. I was hoping it will look similar on the regular c63. idk
Old 08-19-2014, 03:24 PM
shivsiddh's Avatar
2012 C63 Amg
Example of the BS with the VFS 2
Attached Thumbnails Vossen Vfs 2 Wheel question-tumblr_mdaep7pt3d1rxqpmco1_1280.jpg   Vossen Vfs 2 Wheel question-untitled.bmp
Old 08-19-2014, 05:30 PM
Rolf de Graaff's Avatar
C 63 AMG PP
Old 08-19-2014, 10:17 PM
shivsiddh's Avatar
2012 C63 Amg
Originally Posted by Rolf de Graaff
Sick! Can you provide details??
Old 08-20-2014, 12:21 AM
C 63 AMG PP
8.5/10x20 with 235-35-20/275-30-20 Dunlop
Don't know the offset, but had to use a 5mm spacer up front and a special 3mm!! in the rear.
The centerhole in the rear wheels is bigger than standard so that the 3mm spacers could still have a alignment ring.
Maybe they can now make the wheels to fit without the spacers, just ask the guys from Vossen
Old 08-20-2014, 01:01 AM
Roswell's Avatar
2010 C63 AMG, 2009 ISF , 2002 L-Tuned IS300, 2011 ML350
They look good, but I'm pretty sure u need 235/30/20 front & 275/25/20 rear tires... Not 35 series front & 30 seres rear which are too tall.
I wouldn't recommend using 3mm or 5mm spacers as I don't think they come hub centric? U might get vibrations.
Old 08-20-2014, 03:15 AM
C 63 AMG PP
Hi Roswel, you're right about the tire size, my mistake.
For the spacers to be hub centric, that's why they enlarged the wheel centre just to have enough thickness to make room for the center ring on the hub
Old 08-20-2014, 10:12 AM
Roswell's Avatar
Quick Reply: Vossen Vfs 2 Wheel question
