FS: DFW - KWv3 (C63 fitment)
I think you may be confused to what i meant by adjustable. It's not like air where you flip a switch and it changes. They are static but do about .5"-3" drop depending on where you set the collars. They work better than lowering springs alone because a shock is designed to work within the provided range. when you lower a car with only springs that shock isnt designed to work there.
Can't wait to be back in a Black
I also have the single finned grill if your interested. Its a OEM MB part.
David
