C63 AMG (W204) 2008 - 2015
If I have a TSB # is there any way to look it up?
Old 10-14-2014, 10:42 PM
darkus's Avatar
C63BS
In an old thread I found a TSB number that might be up my ally, but I wanted to look it up and hopefully even find instructions from MB to my own work on my car.
A google search on my TSB comes up with a big fat 0, but was wondering if anyone knows of a site that lists all TSBs or better yet has a way to look up a TSB if I gave you the #?
Thanks!!
Old 10-15-2014, 10:36 AM
Valvestud's Avatar
2014 E63 AMGs, 2015 F-150 Lariat, 2010 Porsche C4S
Thanks!!
Please post the TSB and I'll look it up.
Regards,
Joe
Old 10-15-2014, 09:56 PM
roadtalontsi's Avatar
10 C six trizzle
mb doesnt have tsb. they have LI tips documents and DTB's.
Give me the number i can probably help
Old 10-16-2014, 10:07 AM
Valvestud's Avatar
Hmm, I have a TSB for the head bolt issue. Has something changed?
File Type: pdf
Old 10-16-2014, 10:16 AM
darkus's Avatar
C63BS
Regards,
Joe
Thats so awesome of you guys! Here is the L Topic/TSB
Noise sources on instrument panel BR 204
Topic number L168.10-P-055895
Version 2 Design group 68.10
Instrument panel Date 05-01-2013
Validity Model series 204
Im hoping/praying MB provides some kind of document on how to do the fixes, as I really want to DIY it.
Thanks again!
Old 10-16-2014, 11:26 AM
Valvestud's Avatar
Thanks again!
Here you go.
Regards,
Joe
File Type: pdf
Old 10-18-2014, 02:30 PM
Ingenieur's Avatar
C63 AMG
Valvestud
Please?
5448 LI40.10-P-059248.
Old 10-18-2014, 03:07 PM
Valvestud's Avatar
Originally Posted by Ingenieur
Valvestud
Please?
I only have access to those that that would be applicable to a 2010, unless it has multiple year applicability.
What year and what's it for?
Old 10-18-2014, 03:10 PM
Valvestud's Avatar
Valvestud
Please?
Googled it. I see it's for a 2012, so nogo from my end. $16.95 to add another car to ALLDATAdiy.
Sorry.
Old 10-18-2014, 05:25 PM
Ingenieur's Avatar
C63 AMG
Clicking noise when turning
Brake parts hit wheel
Sand wheel where it rubs??
Thanks for looking anyways
Old 10-19-2014, 01:11 AM
ToXicXxX's Avatar
2011 C63 AMG P31
You don't have your rears in the front by some messup (a tire shop perhaps lost track and swapped them), do you? Because that will do it...
Old 10-19-2014, 11:39 AM
Ingenieur's Avatar
C63 AMG
Nope, I don't have an issue, but thanks for the response
I was just asking
I always check their work
They recently mounted the 235 on the 9's and the 255 on the 8's but only one 1 side...knuckleheads
I even had her tip the guys who did it $20! Lol
My wife picked the car up, checked it as soon as I got home from work, took it right back
Old 10-19-2014, 10:35 PM
10 C six trizzle
Valvestud
Please?
It's very vague. Says to open a ptss and contact tac (technical assistance center)
The pictures files are to show you what to take a picture of.... the hub/rotor and back of the wheel where they make contact. Doesnt sound like there is a fix for it yet. Here is copy/paste version.
- Crackling and cracking noises when cornering -
Topic number
LI40.10-P-059248
Version
2
Design group
40.10 Wheels, tires
Date
08-14-2014
Validity
Model 204.#77 with code 785 or 793 (AMG light alloy wheel with cross-spoke design)
MODEL 222.#77/178/179
Reason for change
Validity extended
Complaint
Crackling and cracking noise from the outer wheel on the front axle when cornering
Cause
Under analysis
Remedy
Please open a PTSS case when reporting vehicles with this complaint.
Please attach the following information to the PTSS case:
• Sound file (a video is best)
• Photos of the contact points (on brake disk and wheel) with the wheels removed (see attachment for example photos)
Note:
Your case will be forwarded to GSP for further review, replacing parts (e.g. wheel bearings) does not adress the complaint. PTS will advise on a remedy via PTSS case-by-case and will update LI document accordingly. Please be cognizant there will be a slight delay in response time due to communication in different time zone.
File
Designation
Folie1.JPG.jpg Example photo of contact point on brake disk
Folie2.JPG.jpg Example photo of contact point on wheel
Symptoms
Chassis/suspension / Chassis, noises / Cracking
Chassis/suspension / Chassis, noises / Clattering
Chassis/suspension / Wheels/tires / Tire noises / Rhythmic knocking
Chassis/suspension / Wheels/tires / Rim / Current problems
Chassis/suspension / Chassis, noises / Creaking
Quick Reply: If I have a TSB # is there any way to look it up?
