C63 AMG (W204) 2008 - 2015
What size winter tires?
Old 10-16-2014, 08:15 PM
g-f
g-f's Avatar
996TT
I'm starting my shopping for winter tires.
Local shop that I trust offers Hakkapelliita 8 studded but they don't have the correct size for the rears. Their suggestion is to use the same size on all four corners.
235/40-18
Will this fit my rear wheels? Is the overall diameter gonna be alright? Anyone knows?
Old 10-16-2014, 08:26 PM
ToXicXxX's Avatar
2011 C63 AMG P31
I ran into the same issues.
So I went hakka 7 in 255 rear 235 front. Not a huge difference in the two, 8's just have more studs (aka more road noise).
Old 10-16-2014, 08:36 PM
g-f
g-f's Avatar
996TT
So the 7 are available in the proper size? I'll look into that.
Do you know if all four wheels are the same size?
Old 10-17-2014, 03:01 AM
edisonwu's Avatar
C63 AMG 507 Sedan
235/40-18
Did you ask why they suggest to use same size tires on all four corners?
Old 10-17-2014, 03:05 AM
ToXicXxX's Avatar
2011 C63 AMG P31
Mine are staggered, because I prefer the look. But smaller tires of all the same size in winter is normal, and a fairly good idea (the smaller the tire width the quicker it will sink through snow and grip the road, larger wide tires act as snow shoes, though this is less relevant when you have studded tires). These last few weeks I have been doing 10-20 sets of BMW winter tires, all the 3 series sedan owners are getting 235/40/18 on all four corners.
***235/40/18 will fit on all 4 stock AMG rims, I installed a set last friday infact. Just be VERY carful when you put them on that the rear offset ones go in the back, or your rim will touch your brakes.
Mine are 235/40/18 in the front and 255/35/18 in the back on 710 rims.
Very very common for winter tires. You usually want a skinnier tire all around. A wider rear tire isn't needed because in this case it will reduce traction, not increase it.
We do a ton of summer/winter tires here in Calgary, so if anyone needs them mounted/balanced on Hunter Engineering equipment... Shoot me a PM.
Old 10-17-2014, 07:44 AM
g-f
g-f's Avatar
996TT
Thanks for the info!
It's probably the way I'll go (235 all around) if I can't find Hakka 7 in the right sizes.
My main concern was that the rear wheels were gonna be too large for the 235 tires, but both you and my local shop say it will fit so it puts my mind at ease.
Old 10-17-2014, 10:43 AM
AMGangster's Avatar
2010 C63
You can run the 225's all the way around. I did last year with the Dunlop Winter Sport 4D's. It worked perfectly.
Old 10-17-2014, 10:46 AM
Ingenieur's Avatar
C63 AMG
The manual specs 225/40/18 x 4
Old 10-17-2014, 01:09 PM
CarHopper's Avatar
E63S | X5
I will be running 235/40/18 all the way around.
For one, a narrower tire will be better in the snow. However, main reason is so that next season I can rotate all the tires. Winter rears will wear quickly on this car and i'll want more than a season out of the tires.
Old 10-17-2014, 01:14 PM
Ingenieur's Avatar
C63 AMG
smart thinking
Old 10-17-2014, 01:19 PM
alexmtl's Avatar
2013 C63 coupe P31
Check what tirerack suggests ! I believe it's 235 all around, maybe 225. A square setup has the double advantage that skinnier tires work a lot better in the snow, and you can rotate the front and rears every season !
Old 10-17-2014, 01:44 PM
edisonwu's Avatar
C63 AMG 507 Sedan
TKS. Mine are all 235 I believe, comes from the dealership.
Old 10-17-2014, 01:46 PM
edisonwu's Avatar
C63 AMG 507 Sedan
I will suggest the dealership to do so next month.
Old 10-18-2014, 07:24 AM
g-f
g-f's Avatar
996TT
The best would be four wheels of the same size so you don't need to pay for mounting and balancing the tires every season.
I'll look into this.
Old 10-18-2014, 08:40 PM
ToXicXxX's Avatar
2011 C63 AMG P31
Yes. Stock rims WILL NOT work for this. As the rears have a more aggressive offset then the fronts, so rears on the front will hit the callipers.
Old 12-11-2014, 04:46 PM
krazyking's Avatar
'10 C63 AMG
Can I run winter tires of the size 255/40/18 on my stock 18 wheels? Found a used set on Craigs that would save me a lot of money!
Thanks!
Old 12-11-2014, 05:12 PM
zibby43's Avatar
'20 GLC300 SUV
I run a square (i.e., same size tire on each corner) 225/40R18 setup. Last year I used Blizzak LM-32 tires and a square 225/40R18 setup. This combination was stellar.
This year, I decided to experiment with a more dedicated snow/ice tire (as opposed to a performance winter tire) and chose the Dunlop Winter Maxx tires (225/40R18). These tires have also performed very well in treacherous conditions.
Old 12-12-2014, 06:50 PM
AMG6.3's Avatar
C63
I just had 225/40/18s installed this week all four wheels. I ended up going with Michelin X3s. The narrower the tire the better in the snow.
Quick Reply: What size winter tires?
