how often do you guys get alignments?
on other cars, I align the car with every tire change, but since I need new tires every 5-7k miles maximum on the c63, I was thinking alignments at each tire change was excessive. how often do you guys align your cars?
Received 1,884 Likes
2014 E63S; AMS 100 octane ecu tune; edok tcu tune; BB intakes; dyno tuned
... If there is excessive tire wear, or if the car pulls left or right
Every tire change is not bad on a car where the tires last 30k miles
thanks, guys. I've been getting alignments with each new set of tires, and while the tires wear evenly, the alignment is always off a tiny bit, which is surprising bc I only go about 7000 miles in between tire changes. I never align my other cars more than every 15000 miles, so just wondering if I can go longer on my current alignments. this is mostly to avoid spending time at the alignment shop 1.5 times a year, not so much to save the money.
The drift out of tolerance to to bushings, etc, is so small and gradual that although the car may 'feel' fine it is out of tolerance
And a bit out in alignment is enough to mess things up
I have never had a car measure in spec for the 'before' check
Something is always out
SPONSOR
Since the mid ‘90 model’s, with the ever increasing speed of vehicle assembly lines there has been no front or rear Camber (or front Caster) adjustment facility fitted OEM!
Only current adjustment is front and rear Toe.
To attempt to return vehicle to factory specs to resolve premature inner edge tire wear, improve traction, and fix steering pull the only current alternative for Camber and Caster is to fit offset, slotted bolts (for the front only). But these are inaccurate one only position bolts offering a minimal .3 of one degree adjustment (3mm).
It’s no wonder many owners continually change tire brands or go from one MB Dealer or alignment shop to another trying to get it right/fix the problem!
We saw the need therefore "to fix it right the first time" by designing, developing, patenting (and re-instating from the 1990's) fully adjustable front (and rear) suspension for virtually all models.
The current K-MAC kits have up to 4 times the adjustment of the one position offset bolts (both Positive or Negative). And unlike these offset one position bolts they can be accurately adjusted - under load, direct on alignment turntable (no need to remove and reinstall each time).
Ongoing, precise adjustment of both Camber and Caster settings if altering suspension height, fitting wide profile tires/wheels, curb knock damage or being able to quickly fine tune/change specs on race days. Extra Negative (plus track width) to go deeper into the corners/lower lap times. With the unique K-MAC patented design only requires use of a single wrench/no disassembly.
For the rear, similar kits for precise Camber adjustment (with additional Toe to compensate for the new Camber facility). Importantly unlike the alternative adjustable Camber arms K-MAC rear kits do not move top of tire outwards - this reducing the essential clearance top of tire to outer fender when adjusting to fix premature inner edge tire wear/improve rear traction.
Also instead of spherical bearings as used on control arms which prematurely pound out allowing metal to metal contact. At K-MAC we have developed long life elastomer bushings.
Bonus with the four front and four rear bushes is that they are also designed with twice the load bearing area and replace the highest wearing suspension bushings. And with K-MAC no special tools are required to fit.
