C63 AMG (W204) 2008 - 2015
CEL - Weistec Supercharged C63
Old 10-26-2014, 02:10 AM
charliekay's Avatar
C63 AMG
Hi guys,
Was out driving this afternoon, cruising, not driving hard, CEL came on. No warning, nothing felt funny. Drove back home and plugged in my Bluetooth OBDII scanner, a few codes came up. Car was driving fine but down on power and idling rough.
P0300 - Multiple Cylinder Misfire Detected
P0301 - Cylinder 1 Misfire
P0302 - Cylinder 2 Misfire
P0303 - Cylinder 3 Misfire
P0304 - Cylinder 4 Misfire
P0305 - Cylinder 5 Misfire
Car has Weistec M156 Brisk Spark Plugs.
First thought is the plugs.
Won't have a chance to look at it til tomorrow so any other thoughts are appreciated.
Thanks.
Charlie
Old 10-26-2014, 02:17 AM
mthis's Avatar
Anything W/4Wheels
Did you install the plugs when you installed the blower ?
How many miles /km on them and did you gap then when u installed them ?
Old 10-26-2014, 03:57 AM
charliekay's Avatar
C63 AMG
Installed with the blower. 10-12k kms ago. The shop did them so I presume they did it right.
Old 10-26-2014, 05:26 AM
average joe's Avatar
C63 Weistec Supercharged
Just run the car again and see if the codes come back.
Could just be dirty fuel?
Old 10-26-2014, 07:09 AM
charliekay's Avatar
C63 AMG
I just got back home so I'll try it again in the morning. Bad fuel was my first thought as well considering it was multiple cylinders misfiring at the same time.
Hopefully I'll get a chance to go over it tomorrow.
Old 10-26-2014, 09:27 AM
Merc63's Avatar
C63 AMG
You have lots of km if I remember correctly.
Are you on your stock O2 sensors? Pull the plugs, if they are fouled up and blackish, you probably need new plugs and primary O2 sensors.
Old 10-27-2014, 12:16 AM
charliekay's Avatar
C63 AMG
75,000kms on the car, ~12,000km on the blower.
Stock O2 sensors.
I will check them when I get a minute to go over the car.
My thinking is either.
1. Spark plugs - doubt it, chance of 6 plugs going at once it highly unlikely
2. MAF sensors
3. O2 sensors
4. Bad fuel - The CEL came on ~20kms after filling up the tank.
Who knows but I will let you guys know when I find the problem, fingers crossed it's something simple.
Old 10-27-2014, 12:25 AM
mr747's Avatar
c63
good luck i think it could be plugs not all 6 just one or 2
Old 10-27-2014, 10:32 AM
Merc63's Avatar
C63 AMG
Pull plugs first. These cars run closed loop 24/7 so if you O2 sensors are cooked fueling will be messed up and foul the plugs.
Old 10-27-2014, 04:25 PM
charliekay's Avatar
C63 AMG
Thanks mate.
Will do.
Going to pull the plugs, check the O2 sensor and drain the fuel tank and put try different fuel.
99% sure it is one of those 3.
Old 10-27-2014, 09:54 PM
Merc63's Avatar
C63 AMG
Have fun draining the tank.
Old 10-29-2014, 12:04 AM
mthis's Avatar
Anything W/4Wheels
Originally Posted by charliekay
Thanks mate.
Will do.
From my experience with 02 sensors if one goes u will get cel for misfire on cyl 1.3.5.7 or 2.4.6.8 one side of the engine if both go you should misfire all 8cyl.
What are the chances of 1thru5 plugs going same time ?
Why not mix the gas with race gas before trying to drain it .
Old 10-29-2014, 02:02 AM
charliekay's Avatar
C63 AMG
Didn't get a chance to look at it, so got it dropped of at my workshop for them to do it, they have looked at it and think it is the o2 sensor.
Looking good at the moment, will let you guys know definitely once we have it fixed.
Charlie
Old 10-29-2014, 06:16 AM
mthis's Avatar
Anything W/4Wheels
Charlie
hopefully that's what it is and it's good to go.
Old 10-29-2014, 11:48 AM
jrcart's Avatar
2008 CLK63 Black Series 2012 C63 Black Series 2014 SLS Black Series
How old are the plugs? I had a similar misfire code on my Wesitec C BS this past spring and ended up being a cracked spark plug. Not sure how or why it cracked but I replaced all the plugs and everything has been fine since.
Old 10-31-2014, 05:54 PM
charliekay's Avatar
C63 AMG
Just an update, it was the o2 sensors. Plugs were checked they were ok, cleaned anyways.
o2 sensors replaced and car is back to normal.
Hopefully that was it and there is no deeper issue that caused the misfire which caused the o2 sensors to go, only time will tell.
Old 11-01-2014, 10:38 PM
Rate's Avatar
MY12 C63 P/P
That's great news Charlie... and hopefully that's all there is to it.
Old 11-01-2014, 10:53 PM
AMG893's Avatar
2010 C63 Estate
Out of interest, how would you have drained the tank?
Old 11-02-2014, 01:14 AM
Merc63's Avatar
C63 AMG
You can't unless you have the tool to remove pump cover. You can put a hose on the pump output and hit it with 12volts.
Old 11-02-2014, 01:51 AM
charliekay's Avatar
C63 AMG
What Merc said, was planning on siphoning it out.
charliekay's Avatar
C63 AMG
Thanks guys, took it for a spirited drive yesterday and it ran perfectly, no hiccups.
Old 11-02-2014, 06:29 AM
AMG893's Avatar
2010 C63 Estate
Ahh ok. I think i get it.
Glad its all fixed
Quick Reply: CEL - Weistec Supercharged C63
