codes and lots of them
My car is running like **** rich and missing all over the place rough idle
Here are the codes that I'm pulling up
I have new oxy sensors on the way but I'm not sure what else it could be
2010 Irridium Silver MB C63 AMG Sedan
You may need new plugs, you obviously should get new O2 sensors, maybe you have a manifold leak, maybe you need a tune reflash, it could be anything.
Gotta start somewhere and just keep changing out parts, visual inspection and OBD code read...
Sometimes mods mods mods = codes codes codes
See if it clears up
You only have an exhaust and airboxes, wouldn't bother putting it back to stock for those.
1. Check plugs
2. Check O2 sensors
3. Check MAFs (doubt it)
Chances are 1st or 2nd point will fix it.
1. Check plugs
2. Check O2 sensors
thanks all just waiting for my sensors and plugs to arrive and then i will tackle the problem
Obviously the same problem as before but getting worse.... Your o2s
Stop driving till you have new O2 sensors and Id put in new plugs now. They are probably fouled to hell.
^^ i wont be merc63 thanks for your help
