C63 AMG (W204) 2008 - 2015
The million dollar question on new tires, with a twist!
Old 11-20-2014, 05:36 PM
johnny--2k's Avatar
2016 ATS-V
Haven't seen this posted by anyone, but looking through the options on new rears, after only getting a whopping 5,200 miles out of the crap Pirreli P-Zeros.
Planning to upgrade to the 275 rears, stock 18's, stock suspension, and here is the question:
Has anyone used the BFG G-Force Super Sport A/S? Being in Dallas, there is still significant Rain, occasional ice, and cooler weather, so an ultra high-performance all season wouldn't be a bad idea as this is a daily car. Treadwear (taking this with an 80lb bag of salt) is 400, so pretty healty, and price point is not bad at $193 each listed on TireRack.
If not these, I'll probably go with the PSS as everyone else suggests, or maybe I'll just bite the bullet and go right for the NT-05. Had those on my 03 Cobra and loved them!
Thanks for the input fellas!
Old 11-20-2014, 06:02 PM
rentzington's Avatar
2010 C63 P30
I just got a set of 4 PSS and love the gripyness so far but I don't rely on this car in the rain so it wasn't a huge concern for me.
I will say that i've hated every BFG tire i've ever owned and none of them lasted anywhere close to the mileage maybe got 25% of it.
Old 11-20-2014, 06:15 PM
johnny--2k's Avatar
2016 ATS-V
That's what I was thinking as well. I'm stuck on what to get though...
Old 11-20-2014, 06:22 PM
SaphGreyC63's Avatar
2012 C63 AMG Sedan
Look into the Michelin Pilot Sport AS/3.
Basically an All-Season with higher treadwear version of the PSS. I've had them on for about 8,000 miles so far and I love them. Great grip in the dry, decent grip in the wet and cold, and treadwear is good, still think I can get another decent 3-4000 miles on them (so about 6-7K more than the stock Contis)
Old 11-20-2014, 06:39 PM
Ingenieur's Avatar
C63 AMG
I have had good experience with Conti DWS
I run oem size and load/speed rating(s)
They also make a DW version
Which isn't as suitable for winter
Old 11-20-2014, 07:52 PM
johnny--2k's Avatar
2016 ATS-V
don't know how often I'll need the DWS, but the DW for sure. Looking at the AS/3, will that load rating hold for this car at SL vs XL?
Old 11-20-2014, 08:03 PM
Ingenieur's Avatar
C63 AMG
Oem is f/r 95Y XL / 94Y XL
I would not run SL or lower LI's
This is a heavy powerful car that can pull some serious lateral loading
Old 11-20-2014, 08:10 PM
johnny--2k's Avatar
2016 ATS-V
yeah, that's why the AS/3 never crossed my mind due to the load ratings.
Old 11-20-2014, 08:30 PM
Ingenieur's Avatar
C63 AMG
Here's a chart
It is good for all brands, the rating are a standard
http://www.tiresafety.com/images/tir...t%20manual.pdf
For example using oem 235/40/18
SL is 91 at 41 psi ( oem heavy load pressure) 1356 lbs
XL is 95 at 41 1477 lbs
Plus the XL has stiffer sidewalls
Old 11-20-2014, 10:09 PM
realjones88's Avatar
2012 C63 P31 sedan
You're kind of all over the place considering all seasons and Nittos. My thoughts:
nt05 - Basically drag radials for the street. I wouldn't get these if this is your only car.
PSS - Best grip, but will you really notice a difference over the other tires? Not sure. They are fine in rain as long as temps are over 40ish. They don't grip quite as well in the cold, but are drivable as long as it's dry. You won't be going anywhere on snow or ice though.
Conti DW - still a summer tire, but a nice mix of performance and usability - should be a little better than the PSS in the cold. Won't grip as well as PSS when hot out. I think you would be fine with these in Dallas.
Conti DWS - a very popular all season model that despite being called a "no season tire" by the haters perform just as well as PSS and better than cheap summer tires for most street driving. You can drive in light snow on these. May be overkill for Dallas though - great for areas in the middle of the US that get occasionally snow and very cold weather. 540 treadwear vs. 300ish for DW/PSS.
Old 11-20-2014, 10:35 PM
johnny--2k's Avatar
2016 ATS-V
Yeah, the Nittos were the extreme, haha!
But you are pretty much on point: It's really between the PSS or the DW at this point. Going to check them out this weekend maybe since mine are pretty much toast!
Old 11-21-2014, 12:50 AM
Carreracat257's Avatar
2009 c 63 amg eurocharged
Smile
Have been running Michelin pilot sports A/S run flats and have only been getting 6k miles and there gone just took off my second set. Trying yok s drives. Have about 500 miles on them . They are a lot smother seem a lot more responsive they are 100 times better in the rain and snow. . Thee yoks compare to the michelins are wider and taller feels the gap in nice takes a lot more effort to break the tires loose . Running 275. Rear 245 frts
Old 11-21-2014, 02:16 AM
johnny--2k's Avatar
2016 ATS-V
are you on the 18's? Got any pictures?
Old 11-21-2014, 02:25 AM
Yes on 18's I will take some pics tomorrow looks nice . Almost looks like I have lowering springs because it filled in the rear gap just perfect
Old 11-21-2014, 09:08 AM
2010 C63 P30
all this talk of wider tires makes me wish id gone 275 over stock when i bought my pss.
I'll add that i've loved every yokahama set of tires i've owned i put them right up there with michelin, we have some advan a/s on our mustang right now really good tires wet or dry
Old 11-21-2014, 09:39 AM
deadfission's Avatar
2010 C63 AMG, 2011 Mini Cooper (work)
I have the Michelin A/S on my rears at 265. They've lasted MUCH longer than the PSS that I had on the rears prior. I like the A/S. They're not as sticky but they're still great tires. I have had no load problems what so ever with them. I would recommend them to anyone.
Old 11-21-2014, 12:07 PM
2012 C63 AMG Sedan
I think the AS/3 are rated at 97, which is higher than the stock tires and just as high as the PSS.
Old 11-21-2014, 12:59 PM
johnny--2k's Avatar
2016 ATS-V
damnit... so many options!!!
Old 11-21-2014, 01:12 PM
275/40/18 yok S Drives
Old 11-21-2014, 01:13 PM
For some reason your wheels look so small!!
Old 11-21-2014, 01:15 PM
johnny--2k's Avatar
2016 ATS-V
yeah, why 275/40 and not 275/35 like most others? That's a TON of sidewall!!!
Old 11-21-2014, 01:18 PM
Don't you mess up the speedometer when you change the size of the tires in circumference?
Old 11-21-2014, 03:17 PM
2012 C63 P31 sedan
275/40 is crazy your speedometer will be off by like 10% vs stock 18s. 275/35 is also a lot of sidewall.
275/30 is what most people do for 19" or if your offset isn't high enough 265/30. With both the speedometer will be off 1-2% (not an issue).
Old 11-21-2014, 03:43 PM
zibby43's Avatar
'20 GLC300 SUV
The Continental ExtremeContact DW "max performance summer" tires are some of the best street tires I've ever used. Good looks? Check. Soft/quiet ride? Check. Great dry traction? Check. Insane wet traction? Absolutely. Good steering/turn-in feel? You bet.
Michelin PSS tires are outstanding but the DW tires stack up quite nicely. They're an absolute bargain for what they offer.
Old 12-14-2014, 08:23 PM
AMG6.3's Avatar
C63
Do you have pictures of the fronts? I love it along with taller and more sidewall tire! Any rubbing issues in the rear?
Lastly, how much is your speedo off at 75 mph? Thx
Quick Reply: The million dollar question on new tires, with a twist!
