Help sunroof stuck open
2010 C63 AMG
All, hoping you can help. I opened the sunroof today on my 2010 c63 and it would not close. Does not move at all. All I get from the button/console is a single click noise then nothing happens. I immediately checked the fuse and that looks fine, any ideas?
Having the roof stuck open is very annoying.....!!!!
Thank you in advance for suggestions
Yes
Ours does have key open & close
Hold key near door handle hold lock/unlock
Look in the manual
There is also a synchronizing procedure
My Audi and BMW had a tool in the tool kit that allowed you to manually crank it closed
You removed a piece of trim to access the cranking point
Looked like an offset allen key
The AMG appears not to have this?
Look in the manual
2010 C63 AMG
Yes
Look in the manual
Look in the manual
I tried looking for the manual cranking point but couldn't find one. I also tried resetting it and it didn't do anything either. Will try the remote though I didn't think of that. Thanks
2010 C63 AMG
Do your makeup mirror lights work?
The fuse for the sunroof is number 17, same as the makeup mirrors. Check the light in the makeup mirror, if they are not working it may be the fuse.
2010 C63 AMG
Yes makeup mirrors work fine and visually the fuse looks fine too. Strange to me that the switch clicks like it still has power etc.
Did you ever figure out what was wrong with this?
My sunroof is doing the exact same thing right now. It is stuck all the way closed but will not pop up to complete the seal.
I've tried the remote, no luck and the sync procedure with no luck.
Well after pushing the button 700 times it finally closed. This morning it tilted perfectly, I was able to sync it, and now it seems to be working as it should.
This car is going to be the death of me. I can't handle the increasing number of problems.
I'll take a manual cranking sunroof any days over a powered one. Better yet, I prefer no sunroof at all.
