C63 AMG (W204) 2008 - 2015
ABS, EBR, ESP LIGHT???
Old 12-08-2014, 01:22 AM
EUROwnd's Avatar
2009 c63 amg
Hey guys I recently had my dear tires changed and after the second time driving it with the new tired I am getting a ABS, EBR, ESP malfunction on the dash. My immediate thought is the VSS but being that I just got new tires I was wondering if that had something to do with it???
Old 12-08-2014, 01:39 AM
EUROwnd's Avatar
2009 c63 amg
Also I burnt out to get the tires broken in. Fyi
Old 12-08-2014, 11:35 AM
jvanbrecht's Avatar
2017 Mini Cooper S Clubman ALL4 - British Racing Green
Those lights come on when you lose traction for too long. I got them in the snow once and was spinning in place. Should go away after you turn the car off for a bit.
Old 12-08-2014, 12:31 PM
EUROwnd's Avatar
2009 c63 amg
How long is a bit? I drive it everyday about 10minutes or so each time and my car stays off for 12+ hours. Also is the steering supposed to feel stiffer?
Old 12-08-2014, 11:54 PM
jvanbrecht's Avatar
Oh, thats a problem then. Mine reset after turning the car off for a few min.
Old 12-09-2014, 12:21 AM
EUROwnd's Avatar
2009 c63 amg
Okay here's the scoop let me know if you have any ideas. I got my tires changed, and did a burnout by stepping on the gas and the brake at the same time. The car ran and drove fine after that, it wasn't until the next day that this issue started happening. I can take it apart tomorrow and take a look I am just not sure what to look for
Old 10-05-2016, 05:20 PM
Mercker412's Avatar
2008 Mercedes C63
Hello Euro, sorry to bring a past post back to life but did you ever get this fixed? Im currently experiencing this issue.
Old 10-05-2016, 05:32 PM
EUROwnd's Avatar
2009 c63 amg
yes it turned out that my alternator went bad and had to be replaced
Old 10-05-2016, 05:44 PM
Mercker412's Avatar
2008 Mercedes C63
So you didn't have to replace no esp module right? The mechanic advised my esp module is fried and needs replacing to fix problem.
Old 10-05-2016, 05:46 PM
EUROwnd's Avatar
2009 c63 amg
i only replaces the alternator after that I never saw those lights again
Old 10-05-2016, 05:53 PM
Mercker412's Avatar
2008 Mercedes C63
Ok thanks for info bro.
Old 10-06-2016, 11:37 AM
Alex.currie44's Avatar
2009 SLK55 AMG
I am perhaps casting my brain back in time too far but in some of my earlier cars there would be issues with ABS and ESP lights coming on after some front end work.
As I recall one way to get things back in line was to start the car and turn the wheel all the way left, then all the way right to the stops and then repeat.
Don't know if this applies here but...?
Quick Reply: ABS, EBR, ESP LIGHT???
