C63 AMG (W204) 2008 - 2015
Replacing Rear Turn Signals
Old 12-23-2014, 01:05 PM
glennhl's Avatar
2011 C63
I have a 2011 C63.
I have been getting an intermittent left rear turn signal out message. It's real because the flashing frequency doubles when the rear light is out. I thought it would get fixed when I had the tail light recall performed a month ago, but no such luck.
So I took the car to the dealer and they said I needed a new left rear turn signal light and that it was an LED and built into the tail light assembly. Luckily they covered it under warranty since I had complained before that it was a problem while the car was still under warranty.
First off, is it really true, are the turn signals LED's? And second, is the only way to replace them is to replace the $200 tail light assembly? Seems a bit harsh.
Old 12-23-2014, 01:34 PM
chrisridebike8's Avatar
'10 C63
Yup. With the lighting package, the rear turn signals are LEDs. I have no clue why they didn't make the brake lights LEDs too. There's no way to replace them other than to have a new light put in. It's strange because they should last a very long time. I'd be willing to bet that it wasn't the LEDs themselves, but some other circuitry with the light (some circuit board or something they are soldered to). Good thing it's covered for you.
Old 12-23-2014, 02:49 PM
glennhl's Avatar
2011 C63
Actually I do not have the lighting package. I agree with you that it's most likely something other than the LEDs themselves that caused the intermittent failures.
Old 12-23-2014, 06:05 PM
itzjonjon69's Avatar
12 C63 Coupe
to answer your question
yes only the turn signals are LED
Quick Reply: Replacing Rear Turn Signals
