C63 AMG (W204) 2008 - 2015
Pre-ignition and CEL
Old 01-20-2015, 08:22 AM
JimmyR's Avatar
E63S
Would pre-ignition ie pinging routinely trigger a CEL? Or would I have to run a diagnostic check and look for fault codes to pick up this sort of problem??
The reason I ask is that I have a stock P31 ie no tune and have noticed what sounds to me very much like pinging under acceleration. It seems to be most noticeable for a brief period at relatively low rpm then settles as revs increase. No obvious loss of performance. I thought it might have been due to a bad batch of fuel when I first heard it but have refuelled several times since with several different fuel companies (all 98 RON) and still hearing it.
Old 01-20-2015, 10:37 AM
Merc63's Avatar
C63 AMG
Pre ignition is not the same as ping (detonation).
The car has a knock sensor that will cut timing I'd it detects ping, so I doubt you are hearing ping.
Old 01-20-2015, 11:37 AM
AMG893's Avatar
2010 C63 Estate
i hear a similar noise too, in similar circumstance, but i hear it more in a tunnel, or when near a concrete barrier, as the noise echoes off that, and if the driers window is open, it can be heard.
I have always said i will record it.
Old 01-20-2015, 01:24 PM
Merc63's Avatar
C63 AMG
Probably the lifters or the cam adjusters. They both can make a clicking noise. The cam adjusters when going bad will produce a rattle or metallic clicking noise.
Old 01-21-2015, 04:17 PM
Diabolis's Avatar
W204 C63 Coupe, W166 ML350 BlueTEC, 928GT, C5 Z06 & IS300 race cars, EQE 4Matic+ on order
+1 on both of Merc63's posts above.
Old 01-22-2015, 02:35 PM
nkc
nkc's Avatar
2012 C63 Coupe P31 CF Trim - Eurocharged V7, 2012 RangeRover Autobiography, 2017 GLS 63 Amg
i hear pings constantly in my C63 and if u live in nigeria, am sure u wont mind as our fuel maybe RON 50 , it pings so bad that its a way of life, octane boosters do little to help.
once in a while we get good fuel and the car doesn't ping at all under any load......
Quick Reply: Pre-ignition and CEL
