C63 AMG (W204) 2008 - 2015
Burning smell- follow up, with question
Old 01-22-2015, 03:24 PM
C63KES's Avatar
C63
Hi folks
i recently posted re: burning smell coming from the drivers side front wheel well( it seemed), with no spills obvious to me, no brake/wheel issues apparent and stable fluid levels.
Thank you to all who had suggestions, esp Maximus.
Dealer inspection apparently confirms valve cover gasket leak; being replaced next week.
Is there an easy was for me to look at this and confirm, once I remove the plastic engine cover?
The car is barely 4 years and 19,000 miles, with recent eurocharged tune, mostly driven regularly; is'nt it too soon to have such a gasket leak?
Thank you.
Old 01-22-2015, 10:46 PM
abcut973's Avatar
'12 C63 Black Series, '12 ML350 BlueTech
Yes that is surprising. Not common.
But this would explain no spots on the floor as the leaking oil would burn on the extremely hot headers. Hence the smell.
You don't need to remove the engine cover. Instead I would inspect the exhaust manifold by removing the airboxes. GL
Old 01-23-2015, 02:00 AM
m a x i m u s's Avatar
C63 AMG P30 *EuroCharged*| Porsche Cayenne | Buell XB9SX
The low miles may have contributed to the gaskets drying out and cracking. Cars should be driven, drive it more!
Old 01-23-2015, 10:04 AM
350Zed's Avatar
'11 C63 P31, '06 Infiniti G35 Sedan (sold), '03 Nissan 350Z (R.I.P.), '15 Toyota Hylander
I had the exact same issue with my '11 at 150,000km.
Valve-cover gaskets do fail, and replacement is pretty simple.
Old 01-23-2015, 12:17 PM
C63KES's Avatar
C63
Thanks again for the replies.
Yes Maximus.... trying to drive it more. Fortunately, living in a small town not needing much of a commute. The previous owner had driven only 14,000 miles in 3 years.
Quick Reply: Burning smell- follow up, with question
