What are they like in Winter???
Quebec city here. We got about 170cm of snow this winter so far and the coldest temp so far was -34.6C. Car is great in the snow, but I do have a LSD and Hakka8 studded tires. You must drive accordingly, just today in 4th I buried the throttle and the rear got loose. But it is totally and easily manageable.
Winter in UK? We call that fall over here.
A good set of winter tires and a LSD and you'll be fine.
Darren I'm currently running these :
http://www.vredestein.com/car-tyres/...c-xtreme/info/
235/19 F and 265/19 R on the same 19" multispokes, probably get a second set of wheels this year though to save changing over and rims !
As we don't get much snow, and when we do its nothing like most of the lads here !!, these are great all rounder winter I've found, more grippy in the dry and wet once it gets below 10, and added bonus if we do get a random dumping you'll still be able to get around
2011 C63 AMG P31
Probably the worst high output car I've driven in winter, but this is caused by the extreme low end torque. Mine was on studs and it was still very hard to drive it without the odd slide/tire spin. My M3 is a fair bit better, and it has 275 blizzaks in the back.
But, name me one high output RWD that doesn't have these problems. You cant.
#33
#34
W204 C63 Coupe, W166 ML350 BlueTEC, 928GT, C5 Z06 & IS300 race cars, EQE 4Matic+ on order
FWIV, getting it going on a steep-ish uphill can be somewhat challenging, but as I said, at the end of the day it will make you a better driver and you'll have a lot of fun it the process.
#36
Until last winter when trying to get up a rather steep 30-meter-long driveway from a dead stop, I did not think it was actually possible to literally burn rubber in a foot of semi-packed snow with ice underneath, but I proved myself wrong. The rears were SMOKING and you could smell the burnt rubber by the time I managed to get the car to the top (I also lost about half the tread on the rears in the process, which significantly shotened their life but it was late in the winter anyway).
Had to go back out a couple of hours later and it was still dumping snow by the bucketloads. When I got back, I asked a couple of other poor souls caught up in the blizzard if they would mind helping me out. They thought I meant "give me a push", but insted I just popped the trunk open and just asked them to sit on it with their legs hanging out over the rear bumper, which they happily did. This time I made it up with almost no drama at all, but I did give it a blip or three with the TC off. Afterwards they kept asking me if I could please give them another ride again.
P.S. I did buy three 40 kg bags of sand that I could put in as ballast if needed, but so far have not had to use them at all. Having a full tank of gas and lowering the tire pressures somewhat (I was running the snows a bit high) is apparently enough to get you out of anythign even with all that tourque.
#37
I thought about the sandbags in the trunk but the thought of potential flying projectiles in the event of an accident is a huge deterrent.
#38
On days that you'd actually need the sandbags, chances are you're not going to be doing more than 40 km/h at the most, so it really wouldn't be an issue.
