How often do you change your oil?
13 C63
I have a 2013 c63 with 7500 miles. I got service A done last April at 4500 miles. I'm now getting the "check oil at next refueling" warning. Do I need to take it for service B already at just 9 months and 3000 miles after service A?
Ford Truck, 2014 C63 AMG 507
From the owners manual...
I check mine frequently and always keep a few qts in the garage. If I were going on the road for a trip I'd store a few qts in a box in the trunk.
General notes on the oil level
Depending on the driving style, the vehicle
consumes up to 0.9 US qt (0.8 liters) of oil
over a distance of 600 miles (1,000 km). The
oil consumption may be higher than this when
the vehicle is new or if you frequently drive at
high engine speeds.consumes up to 0.9 US qt (0.8 liters) of oil
2015 E63S AMG & 2013 GLK350
I changed my oil at 2500 miles, 5000 miles and every 5000 thereafter - in 27000 miles I had the car it never consumed oil. I'd always check the level before an oil change and it was at or very near the full mark, never had to add.
2012 Diamond White C63 Coupe
When this happens I usually do a top off as mentioned and the issue goes away. I have been changing oil every 7,500 miles or so, but I think a little higher is recommended..I just like to be safe since I daily drive
I think most here change their oil too soon but if you're doing 10k miles OCI's you should have a UOA done if you haven't already. It'd be well worth the $25 to check on the wear metals IMO...probably should get a TBN reading (extra $10) too while you're at it.
Dear God I can't believe we're having this discussion again. Yes, manual. Every 10K or annually. If you want to change more often, that is forbidden by the mighty MB AMG God, so don't even put it out there. Your engine will be stuck down by lightning bolts from above and you'll be forced to live out the rest of your days driving at Kia.
(1) your head bolts will fail,
(2) you will automatically have the wrong size spacers,
(3) your tires will wear out,
(4) you will have purchased the wrong brake pads
and you will no longer be able to do burn outs, only "burn ins". and since this may come up the answer is Mobil 1 0W-40 and yes they sell it at walmart. and a mityvac is nice. don't get fake chinese knock-off oil filters. and yes you can recycle your oil.
W204 C63 Coupe, W166 ML350 BlueTEC, 928GT, C5 Z06 & IS300 race cars, EQE 4Matic+ on order
I do mine every 6K km with M1 0W40. Yes, some may consider it overkill, but I ain't afraid of them wrong sized spacers...
Haha...I do mine once a year which is about 5500km. If I go on a long trip I always get a tail wind my car likes me so much. I use a MB filter because it costs too much to buy a cheap one from the US and ship it here. Besides the people who live here have to eat and heat their homes too.
I do mine every 5000 miles so roughly once a year.
If you track aggressively and regularly your car you might want to do it more often.
Incidentally, driving mostly short distances in the city where the oil doesn't get up and STAY up at the usual 105 C for a period of time so some of the the water in the crankcase can evaporate is another reason to change it more often (water is a byproduct of combustion and it turns the oil acidic). Yet another reason to use an oil with a higher TBN if you mostly drive short trips.
Wait, we need to change the oil in this car? I thought it was electric.
The P85D with its ~700 hp and 4WD is a different beast altogether. That will leave anything in the dust, but again it doesn't corner well because of all the extra weight.
Now, comparing the two is really more of an apples and oranges thing than anything else. The fact that Tesla has managed to build even the P85 is a great accomplishment; the P85D is on another level altogether. I'd love to own either one and use it as a DD. The problem with fully electric cars is that unlike a C63 you can't just stop by at the nearet gas station and in 5 minutes have juice for the next 350 km - the Tesla has to charge 1 hour for every 35 km, so 10 hours for 350 km (assuming that you have a 240V charging station, otherwise it's even longer). The ONLY thing holding back electrics is the charging time for the batteries, and unfortunately it's the big oil companies that are severely hampering the development of new fast-charge battery technologies. If it wasn't for the trillions of dollars that big oil makes annually, a $100 billion annual R&D fund could likely develop batteries that would make internal combustion engines obsolete in 5 years. Just as a reference point, big pharma spent $112 billion on R&D in 2013. Volkswagen on their own spent $11.4 billion (Daimler did $6.6 billion) - so it's certainly doable if it wasn't for the economic and thus political obstacles.
