How do you "tune" these beasts??
2014 C63 AMG 507
Hey all,
Newbie question here. I searched but couldn't find an answer. So how do you tune the C63? I am used to tuning a vehicle by loading a tune from a computer onto a DiabloSport Predator, and then taking the Predator and hooking it up to your OBD2 port. Then you download the tune to your car. Something tells me with these cars, they are different.
So what happens when you get a Eurocharged V5 tune, or whatever tune you want?!?! I ask because I want to get headers for my 507, and then update the stock tune to account for the variables, and maybe shut off a sensor or two...lol.
Thanks!
Wes
Thanks!
Wes
2014 C63 AMG 507
I would say yes, but I'm biased! There are many others out there, but I believe EC is one of the only few that is done via handheld. Tunes by RennTech, Brabus, etc... all require you to send them your ECU, so your car is down for days or weeks depending on turnaround time.
2014 C63 AMG 507
Just so you know, you'll be able to turn of the CELs (Eurocharged will do this) for being catless, however, you will not pass inspection. The monitors will not set to "ready" therefore you'll fail.
So yeah, just because the CEL isn't there doesn't mean you'll pass.
As for the tune, there are a few options. Either pull the ECU and send it to Weistec or just get the handheld from EC and they'll go back and forth with a few emails with you, and done.
2014 C63 AMG 507
Received 2,810 Likes
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Not sure that there is one. Eurocharged at least sells the mygenius and the tune together and I'm pretty sure they won't just sell the tune. That being said, do a thread search and you'll see a number of us who've used mygenius have posted instructions as it's "normal" to get error messages, and you have to repeat steps, etc., which from a user-experience point of view SUCKS but it ended up just fine in the end with the tune installed properly. So you may be stuck with my-notso-genius if you go with EC. I do like my EC tune, however, and I think most have been very happy with it.
2014 C63 AMG 507
Yup, that's what I am afraid of. I was going to go with the MBH headers and mid pipes from them, but I am not sure if that would trip a CEL. I need all sensors ready to pass emissions here in northern Virginia. I would still have the secondary cats, but don't know if that is enough. Also I don't know about the positioning of the O2 sensors with this setup. Thanks for the notice though! Much appreciated
Personally, I am going to avoid headers all together and just remove my secondary cats and resonator. Little more bark, and no headaches. It'll give a little more pep but its minimal.
The sensors are pre and post the primary cats. You can have headers with 200 cell cats moved down the system (so nearly where the secondary cats are now) and relocated your o2 sensors down there with them. That should get you by. Just make sure you don't have the CEL turned off because even though you would pass emissions, having that off wouldn't allow monitors to set.
Btw - I'm in NY so I have literally the same types of standards that you do. I'm not in a sniffer state or a state without inspection.
'13 C63 AMG P31
2014 C63 AMG 507
Yeah, you'll need headers w/ cats to pass emissions. The secondary cats are meaningless and there to keep certain folk happy. You'll be able to remove those with no consequence what-so-ever. You could even take them out right now, no tune, and you'd get no warnings.
2014 C63 AMG 507
^ Yes, I believe that is the point and why MBH offers that. Contact them, they'll know best about what would be required for that system. You'll just be bringing down the o2 sensors to those cats.
2014 C63 AMG 507
SPONSOR
Location: Houston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
Eurocharged Performance ML63 and TT lambo
Hey all,
Thanks!
Wes
Thanks!
Wes
Ya, the mygenius isn't great, but once its setup its easy to use. We can also send you files to update the tune if you change mods (headers etc)
We have the tune and handheld on sale for $699 right now!
2014 C63 AMG 507
Thanks! I'll be in touch!
Just installed MBH longtubes with 200cell cats. Cats come with 02 bunges but rear 02 sensors come up short. I ordered 2 02 connectors and 2 rear O2 sensors to build a adaptor harness. Otherwise the header and exhaust fit is perfect. i had the same concern of OBDII readiness and after being specific with tuner, they stated it can be done to keep monitors ready. I Just sent ECU out and once I get it back I will see what happens with readiness monitors.
2014 C63 AMG 507
Parts may come in today or Tuesday. Ill get you mb part # tomorrow for adaptor build. Maybe MBH has something already but I didn't contact them. Visual 3-5 inch difference. I also tried to relocate harness but still no luck. Front 02 sensors are longer and appear to have the length but connector end is not correct. Easy enough for me to just build a small adaptor harness plug and play and should be good to go.
