60k maintenance
2009 c63 amg
60k maintenance
I just did an oil change on my 09 and they mentioned that there are other things I should do at 60k as well. They mentioned tightening up the suspension, trans fluid, cabin filter, and spark plugs. How much of that stuff is really necessary?
trans service should have been done at 40k on your car, spark plugs are due, cabin filter is every other service which if done every 10k like it's supposed to should be due at 60k.
rear diff should be done with the trans. I thought that was around 50k miles. cabin filter you can do yourself it's very easy there is a DIY on the forum. I thought plugs were 100k miles?
as for what's necessary I'd say all of it just follow the maintenance schedule in the book.
Yes that sounds correct if the transmission was not done at 40K. Also the brake fluid should be changed. There is no mention of changing the diff fluid in my 2010 Service Booklet unless you have the AMG LSD but it is probably a good idea to get it changed.
