C63 AMG (W204) 2008 - 2015
Brake pad differences
Old 02-04-2015, 03:36 AM
t4orce's Avatar
2011 C63 p31
Apologies in advance if this has been answered before. I searched but did not find.
Can someone tell me if the brake pads for a p30/p31 car are different than the standard car?
I just ordered some Porterfield pads and the supplier didn't ask me if I had the performance pack model so I assumed it is the same. It's got me thinking now though.
Old 02-04-2015, 04:30 AM
bhamg's Avatar
C63 AMG
Hmmm, I'm a little surprised. I thought they were the same but I checked for P31 (2010) and it shows a different part number and price:
https://www.parts.com/index.cfm?fuse...3-%20Liter-GAS
Of course that doesn't necessarily mean one wouldn't work in the other...it seems they do based on conventional wisdom here.
Old 02-04-2015, 07:07 AM
Exhibit13's Avatar
2010 c63 (p31) w/LSD
They are the same size so the porterfields will work on any c63. The difference was the p30/p31 pads use a more aggressive compound than the standard c63.
I have the porterfields on my p31 and they are very nice, they work well but they don't squeak at all unlike the stock pads that drove me nuts!
Old 02-04-2015, 08:49 AM
aussie e55's Avatar
2009 C 63
Smile
how about dust ? thanks
Old 02-04-2015, 08:54 AM
abcut973's Avatar
'12 C63 Black Series, '12 ML350 BlueTech
Yes they have different part numbers. But they are interchangeable.
As mentioned the difference resides in the compound used. No matter which OEM pads you will go for they will be dustier than aftermarket product.
Old 02-04-2015, 09:05 AM
Exhibit13's Avatar
there is less dust compared to OEM
Old 02-04-2015, 07:54 PM
t4orce's Avatar
2011 C63 p31
Great to know. Thanks for all your input. I'm looking forward to less dust and noise. Oh and also the savings from not having to buy OEM.
Old 02-04-2015, 09:43 PM
Exhibit13's Avatar
no worries, glad to help. I just went through this all a few months back. I love the brakes on this car but the stock pads were horrible. Super dusty and squeaking so bad, got people turning thier heads for the wrong reasons. The Porterfield's perform a little bit better than OEM pads too I feel.
Old 02-04-2015, 09:53 PM
Phorte's Avatar
2015 C63S
this this and this. i'm so sick of the dust. good thing my (stock) wheels have Opticoat for protection so the dust comes off easily but it's annoying how quickly it builds up again.
Old 02-17-2015, 08:23 AM
Former Vendor of MBWorld
RacingBrake's Avatar
CLS550
Try RB's ET500 pads - Low dust and no squeak guaranteed.
Front: http://www.racingbrake.com/RB-ET500-.../pd1291-35.htm
Rear: http://www.racingbrake.com/Brake-Pad...1373-33-01.htm
Testimonial of how ET500 works for new SL550
https://mbworld.org/forums/sl-class-...ml#post5939978
Hundreds of other MB owners enjoy RB brake pads along with our two piece rotors.
RB has more brake options including C63 two piece rotors & pads than any competitions.
http://www.racingbrake.com/category-s/7136.htm
Your one stop source for your brake replacement / upgrade.
Old 02-17-2015, 09:41 AM
jcfay's Avatar
2018 AMG E63s
I don't understand how a pad can generate less dust. If the dust and pad breakdown are related directly to stopping power, and pad and disc composition, if you switch to a pad that generates less dust I'd think something else would have to give. Does this increase wear on the disc? Or is the difference just in the qualities of the pad and dust generated (in other words it's less likely to stick to wheels, or dissipates better, etc.)?
Old 02-17-2015, 10:19 AM
Exhibit13's Avatar
different pads are made of different compounds. Each manufacture has thier own "recipe" if you will, some better than others. Just like any other product cuts are made in research, quality and performance by some brands to favor a lower price point.
Old 02-17-2015, 07:28 PM
t4orce's Avatar
2011 C63 p31
Having fitted the Porterfield pads and used them for about a week or so I can vouch for less dust, no noise and same feel/performance as OEM.
I can put up with the dust but the noise and squealing of the OEM drove me nuts plus it was embarrassing when pulling up to lights or stops. Detracted from the pops and gurgles.
Old 02-18-2015, 03:22 PM
rpurdy210's Avatar
2009 c63
brake pad recommendations
wondered what advice i might get on replacement pads on my c63. There are OEM pads whick are expensive, there are EBC pads, red and yellow available for this car, and Centric makes cheap pads and what they call OEM replacement pads which they claim are OEM material spec. I have done a lot of brake work on my past cars and know that what the pads cost and how they work and last can vary quite a bit. What i am after is a good pad that will brake as good as OEM, without spending OEM money. any suggestions?
Old 02-18-2015, 03:50 PM
Phorte's Avatar
2015 C63S
Do a search and you'll get your answer - and you'll find that this very thread you've just posted has given you the most common recommendations: RB's ET500 or Porterfield R4S.
Old 02-18-2015, 04:59 PM
Exhibit13's Avatar
what he said!
Old 02-19-2015, 09:38 PM
604 C63's Avatar
2012 E550 Cabrio
I second everything Exhibit says. He is spot on.
About this issue in this thread, anyways.
Old 02-19-2015, 09:50 PM
Gerry_M's Avatar
W204 C63 Bone Stock; E36 M3 Supercharged 400WHP; X5 parts eater
Anyone ever get the steering shimmies when braking after a bit of time. I find this always happens when I dont put in stock pads and disks even though there is plenty of life left in the pads and rotors. They might be cheaper but I end up swapping them out more often than stock.
Old 02-19-2015, 10:19 PM
Exhibit13's Avatar
no issues at all. If I had known how much better these pads (Porterfield) were I would have changed to them the day after I bought the car. The swap was super simple and for the cost I couldn't be happier.
Old 02-19-2015, 10:23 PM
Exhibit13's Avatar
I am always correct, unless you ask my wife then I am always wrong!
Old 02-19-2015, 10:40 PM
604 C63's Avatar
2012 E550 Cabrio
I thought I was wrong once, but I was mistaken.
Old 02-19-2015, 11:29 PM
604 C63's Avatar
2012 E550 Cabrio
No. I have purchased brake parts that were cheaper in terms of price, but never in terms of quality. I have a heavy, high horsepower vehicle so I make sure that if I do anything to the brakes it is an upgrade. Upgrading for less than MB prices is made easier by the fact that I have a P30. I would refer you to the ACG thread re brake parts:
https://mbworld.org/forums/c63-amg-w...-packages.html
Old 02-21-2015, 12:40 AM
Gerry_M's Avatar
Unfortunately or fortunately, I dont have a P30... so its hard to justify these prices given MB sells my rotors at $150/piece
Quick Reply: Brake pad differences
