Rough Idle and Shaking
I've noticed in my wife's C63 that when it's been driven for a while during the day and it's hot, it shakes and the revs go up and down.
Also on idle i've noticed from standing on the outside of the car the idle keeps going up and down. The engine idle goes up and down.
Also i've noticed when the car is parked in traffic on a downhill it likes to shake when hot.
MAF Sensor?
Plugs? (they were changed 10 000km's ago)
02 Sensor?
MAF Sensor?
02 Sensor?
PaoloCarnevali (06-16-2019)
MAFs, plugs, cam sensors...
Really hard to tell with no CELs. And taking it to the dealer with that list gets expensive quickly as they'll check everything.
Nothing has come up on the dash..
Can i get Mercedes to check for codes?
Also could it be exhaust leak? I don't know i just have a feeling that it could be an exhaust leak for some reason.
Codes can still show up with a scanner even if it didn't trip the CEL. Here in the US, some stores will check for free. Or buy an OBD2 scanner and check it yourself. You can get an inexpensive one and I've found it very handy to have one.
and if youve bought a eurocharged tune then you already have a scanner in the mygenius unit.
I don't remeber the exact options but there is a data capture mode in the menu, or called something similar like data log
i know it will capture information on the vehicle, pretty sure it would show codes.
2010 C63 P31 AMG
I just had my fuel check valve and fuel pumps changed out. Idling was rough and would have violent engine shakes that came along a check light. Concerning your issue, this could be a possibility. Would do a fuel pressure check and see how it is during idle.
2011 C63 AMG P31
Mine had that issue. Didn't rattle, but it was always searching for idle RPM, and would go into limp when pushed hard.
I just went through a similar symptom....turned out to be 2 bad throttle actuators for me. RPM's would bounce while driving, car would go into limp mode while driving.... Sometimes my CEL would come on, sometimes it wouldn't.
Took the car to mercedes, checked for codes and it was all clear.
No codes at all.
Still notice by standing outside the car that the engine revs keep going up and down.
Needle only moves slightly, but you can hear the engine isn't stable on a certain rpm. It keeps fluctuating up and down..
It sounds like someone is slightly putting their foot on the accelerator then letting go, and repeating.
No codes at all.
When my car went into limp mode and I pulled the plugs Bank 1 had been shut down completely. Only Bank 2 fired, so it was no surprise the engine had no power whatsoever and was massively lumpy in operation. Is that standard limp mode operation or are there different limp modes based on what the codes indicate?
No codes at all.
No codes at all.
Yes.
After initial startup when the needle steadies, it's fine.. until it gets warm/hot or unless it's been driven hard.
Then it starts to fluctuate up and down.
