Pissed off!!
2004 SL 55, 2014 E550 4Matic
Pissed off!!
Can't get this airbag off of the steering wheel. Can someone tell me exactly how to get it off? I've been trying with a small flathead and I can't get it to come off. Can someone explain to me in detail how to get it off. Really descriptively. I've read the forum on replacing your steering wheel trim but I did everything and can't get it
Ford Truck, 2014 C63 AMG 507
^ Nice find.
That is exactly what you need to do. I would disconnect my battery t oavoid any static electricity or else triggering the airbag.
That was the most perfect thing ever!!!! I put an Allen wrench in there and it popped right out the whole install took me 10 minutes. You guys are awesome!!!
Received 2,810 Likes
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Ever since I removed mine to do the trim and paddles, the airbag light won't go off. Disconnected the battery during the process and everything. Anyone else have this problem?
Unless you have a faulty and damaged airbag. Either way it needs to be tested and the fault cleared. Don't play with safety in this case.
You need to disconnect the battery before working on the wheel and not reconnect until everything is back in place. Looks like you disconnected your airbag with the battery ON. Only fix is to go to the dealership get it cleared.
that's odd. I just swapped out my wheel for a carbon fiber one. disconnect battery, swapped wheels, reconnected battery no lights.
maybe disconnect battery pull the airbag and re-check all the connections.
Does your dash say "SRS malfunction"?
Even though the connections are checked once triggered the light won't come off by itself. Only the dealer can clear it (or anyone having the tester/software). If I recall they charge $168. Happened to me when I put the car back to stock. While working on the car I needed power at some point and reconnected the battery but I forgot my airbag was not connected yet. Got the SRS malfunction light and it would not come off no matter how hard I would reconnect and check everything back. Even disconnecting the battery didn't do it.
Nope. Just changing out the steering wheel trim and paddles. I was also changing plugs at the time, but that's irrelevant. 2012 Coupe. Yes, the dash says SRS malfunction when I start the car, and I have to hit OK to get it to go off. Sucks. Hate going to the dealer here, they're *****s. (sorry, doodieheads)
