Anyone do a compression test?
What were your results? I got 180psi all around give or take a few psi. Cars been sitting for 5 months. I am not sure if the throttles were opening when I pressed the gas however.
180 across the board actually sounds perfect given the compression ratio. So, odds are it's in great shape with respect to that. And IIRC you cleaned out any carbon when the s/c went on so that's not a factor.
