help on oem reverse camera retrofit
2012 C63 Sedan
i got the Wire Harness /camera and installation guide from the forum. before i started, i am not sure if i got all the stuff cos some parts are not included in the kits... just want to make sure i got everything ready
pic1: the installation guide on wire harness: it mentioned yellow/grey line to reverse light
pic2: what i got in the kits
pic3 &4 : it mentioned i need to have a potential distributor to connect the yellow/grey line together with the same color line that has been there (reverse light) but seems all sockets are full..
question: where do i get the potential distributor and how to fix it?
pic5 & 4: do i need to open the fuse carrier in the kit and insert in the fuse carrier on the car? a bit confused why they supply with sth. already there
thx for patient and let me know if you have any ideas
Installation guide?
I recently bought this kit as well and if someone could point me in a direction where I could find the installation documentation that would be wonderful. It appears to be the following Daimler AG document number: AN54.65-P-0030-03CW
Is there a PDF version of this document available anywhere? Thank you.
Hi, did you finished the installation. If yes could you let me know how you did it. thanks
