Weistec Supercharged stg3 C63 Hits World Record , 9.902 @141mph
My C63 recently went 9.78@140mph. The run's ET and trap speed were 100% legit. However, it could not be verified due to the 60ft timing being off. YAS called us again to run the car. They had switched the timing sensors that measured the 60ft. The car was run again and this was the result:
Here is a Video of that run:
We couldnt get the car to hit 9.78. The wind was blowing agianst us and the weather was at a higher DA. Plus, the transmission was sliping that the CEL popped. The RPM was hitting the cut-off line almost on every gear. If that hadnt happened, the car would improve maybe 0.1-0.3 seconds in ET. The car was diagnosed afterwards, and this was the fault code:
The transmiison will be sorted out hopefully this week
All this, but the car was still able to hit a 9 second pass and record the best ET for a C63. The run will be verified by dragtimes shortly and will be a new world record.
A huge thanks goes out to Weistec Engineering for building this Beast and PP-Performance for tuning the car and putting all the drag setup on it and arranging the runs at YAS Marina. Nice work
It will undergoe a big project right now and be tracked later when its finished
Nice run congrates
Can you please confirm what tyres you were using front and rear please
Received 2,810 Likes
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Nice clean run. Congrats.
Congrats on a nice run and record! Getting into the 9s is no easy feat. Do you have a mod list? I know you're using the Weistec sc with small pulley but what else?
Thank you guys on the kind words
Thanks Ahmed. I Believe my mods were listed by weistec on my 10.2 run previously, weren't they ?
Its ok though,
I have the Weistec Built engine package
Weistec 3.0l SC
60mm pulley running on 18psi boost
Weistec Ice Tank
weistec catch can
Weistec upgraded 722.9 transmission plus valve body tuning
Weistec Spark Plugs
I had custom suspensions made by PP-Performance used for drag which I will post about later
The car was on VP103 race fuel
Its ok though,
Weistec 3.0l SC
Weistec Ice Tank
weistec catch can
Weistec Spark Plugs
Congrats! Impressive! You got into the 9's with less mods than I did and it looks like you left a little on the table so you will go even faster yet.
