C63 AMG (W204) 2008 - 2015
Trickle charge battery
Old 03-22-2015, 05:09 PM
GQsmooth's Avatar
ML
Do you guys usually use the battery in the trunk, or the one in the hood?
Old 03-22-2015, 05:32 PM
Sincity's Avatar
We only have a battery in the trunk. Also, the stock one, I believe, is an AGM battery and your "battery tender/maintainer" needs to be AGM compatible. I bought one from Harbor Freight and it says it is NOT AGM compatible.
Old 03-22-2015, 05:39 PM
GQsmooth's Avatar
ML
According to the manual, you're supposed to hook up to the terminals in the hood for any sort of charging.
The charger I have is AGM compatible, I used it for my GLK a couple years ago. It's a Genius 3500.
Old 03-22-2015, 09:41 PM
afaedC63's Avatar
2014 E63S Wagon, 2013 odyssey
When I had my c63 I hooked mine to the battery in the trunk for 6 months and it started up and ran with no problems. Just don't forget the sta-bil.
I didn't see in the manual what you saw (probably just missed it) so I talked with my shop foreman and he told me to hook it to the battery. My e63 is stored the same way.
Edward
Old 03-22-2015, 09:52 PM
m a x i m u s's Avatar
C63 AMG P30 *EuroCharged*| Porsche Cayenne | Buell XB9SX
Originally Posted by afaedC63
When I had my c63 I hooked mine to the battery in the trunk for 6 months and it started up and ran with no problems. Just don't forget the sta-bil. I didn't see in the manual what you saw (probably just missed it) so I talked with my shop foreman and he told me to hook it to the battery. My e63 is stored the same way. Edward
It works either way, obviously. It's a safety issue.
Old 03-22-2015, 10:00 PM
afaedC63's Avatar
Never thought of it being a safety issue... can you explain which is safer and why?
Old 03-22-2015, 11:09 PM
Gasses get released from the battery, so accidental sparking *can cause an explosion. This is most likely a case of hyper-CYA MB lawyers.
Quick Reply: Trickle charge battery
