Hate to gloat, but Weistec stage 3, is ordered!!!
ford svt's, and C63!!!
Just like the title says, I'm pumped and in a week or so, it should be headed my way!!! I might even make it to a dyno day down in SLC on the 18th, and possibly have some numbers, hopefully "after", but with my recent work schedule, it might have to be "before" numbers.
You should do before numbers anyway. Then compare to the afters
I need to go back and get a dyno after my row box install, but i'm not really expecting much so I havent done it.
Received 2,810 Likes
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Jelly... good luck and let us know how it goes. Are you doing the install yourself? Post up a DIY if you do!
I say 680rwhp good luck mate your gonna love it
You should be well over 600rwhp.
Get ready for the biggest wow factor you can do to these cars. Putting a stage 3 on them is like strapping an acme rocket on, night and day difference. The amount of torque produced throws you back in the chair at 2500rpm.
These cars are very very fast with this mod and there will not be much that will touch you after, even sport bikes, unless it's a 1000cc.
I'm not too worried about before/after numbers, not even so much "after" numbers either. As long as she gets nicely improved track times, and I can easily beat out my buddies GTS viper that has been a really close match with for quite a while now, I'll be fine. Oh and people around here already know it runs pretty well the way it sits now, hahaha!
I actually already have "before" numbers from the local dyno that's very stingy compared to the one I'm going to in slc, but it really doesn't matter a whole lot to me, as long as it performs well for the way I use it.
What are you boosted guys doing for a boost guage? I was planning on just hooking up a temporary guage, and just "checking" once in a while.
I also don't know what to expect for boost either, I live at 6500' elevation, so I know I'll be a little shy on boost, and power, but that's ok as the guy at the traffic light is also breathing the same thin air. I had an 04 Cobra that made around 12-13psi, I sold it to a guy in Texas, and he said it made almost 19psi when he received it!!
I might see if I can swap the air-boxes from stock to the rows to see if there's really any real restriction in the US air intake system as I'm very skeptical, and the row setup is quite pricey for what it is. So maybe some Row airboxes for sale here if they do nothing on my combination after checked on the dyno.
I know a supercharged engine needs a lot of air, but I really can't wrap my head around the stock intake system being much of a restriction.
The row boxes are mandatory with stage 3 I thought for tuning purposes...
You will be down boost probably around 7-8psi. I have a boost gauge mounted under the hood, there is a port on blower intake manifold.
I'll have it connected to the dyno's a/f ratio system and have them shut me down if it goes out of whack when trying them, if it's a quick/easy swap from stock to the rows I'll try it.
What are you doing about the tranny? Just rolling the dice?
Congrats on the purchase!
The C63 with a SC is a whole new animal. I was fortunate to drive a Stage 3 here in Toronto and that car was ridiculous. Got to 200 real quick
As for the transmission, that's a toss up. I would swap out the transmission at the same time, would hate to be beating on that bad boy only to break the transmission on the freeway.
