c63 507 led and hood part number
For the black gloss DRL surrounds, these are the numbers.
507 DRL Trim - driver side: A 204 885 37 74
507 DRL Trim - passenger side: A 204 885 38 74
Apparently searching and etiquette aren't your strong suits.
Item | Part Number
-10 204-880-12-57 -- Standard Hood
+10 204-880-13-57 ** 507 Hood
+15 204-750-01-44-9040 ** 507 Air Inlet Grill L
+15 204-750-01-44-9999 ** 507 Air Inlet Grill L
+15 204-750-02-44-9040 ** 507 Air Inlet Grill R
+15 204-750-02-44-9999 ** 507 Air Inlet Grill R
+25 003-991-02-70 ** 507 Mounting Clamp (qty 3)
+27 204-885-00-41 ** 507 Bracket L
01-41 ** 507 Bracket R
+29 000-990-54-92-9051 ** 507 Expansion Rivet Fastening Bracket Left 6MM (qty 4)
+29 000-990-54-92-9051 ** 507 Expansion Rivet Fastening Bracket Right 6mm (qty 4)
30 204-880-07-28 -- Hinge L
08-28 -- Hinge R
40 019-990-12-01 -- Bolt w Flange
50 015-990-21-01 -- Bolt for hinge to engine hood
90 204-817-06-16 -- Badge
100 204-880-00-29 -- Gas Operated Spring L
100 212 980 05 64 -- Gas pressure strut R
110 204-880-01-27 -- Spring Element for engine hood
120 169-889-12-95 -- Intermediate Layer for spring element
130 204-880-08-59 -- Hood Cable front
140 204-880-07-59 -- Engine hood release cable rear
150 204-880-01-20 -- Release Handle for engine hood cable, clipped
160 001-995-35 77 -- Line Holder
170 212-880-00-60 -- Engine Hood Catch
180 N910105 006023 -- Hexagon Head Bolt
190 204-880-00-64 -- Safety hook
200 N910105 006023 -- Hexagon Head Bolt
210 204-682-06-26 -- Sound Proofing
+210 204-682-12-26 ** 507 Insulation Engine Hood
220 001-988-03-25 -- Plug-in Mounting
240 000-988-44-40 -- Stop Buffer
250 N910112006001 -- Hexagon Nut
Item | Part Number
08-28 -- Hinge R
MY12 C63 P/P
How did you replace the DRL trim?
Did you have to remove the front bumper or is there another way to change them over without doing all of that?
Cheers...
'13 C63 AMG P31
I just had the dealer do it for me when they replaced one of my dim DRL's. I do not believe they had to remove the front bumper. It looks like you can just unclip/pop up the tabs (6 I think) and pull the chrome trim out. Not sure if jacking the car to reach under the bumper will help or not. If nothing else, ask the dealer, I'm sure they wouldn't mind giving advice.
MY12 C63 P/P
