C63 AMG (W204) 2008 - 2015
C63 W204 Faultcodes P0073 and P2069
Old 04-24-2015, 06:37 PM
Energiiz's Avatar
C63 AMG W204 SOLD: CL55 AMG V8 Kompressor E55 W211/CLS63 W219
Hi,
I have a C63 AMG W204 that i just picked up from the paint workshop. They painted the front bumper.
The day i took the car i saw that the engine lamp was on, so i went home to check the fault codes becouse i have a diagnostic software and the fault codes was:
P0073 Ambient Air Temp. Sensor Circuit High input
and
P2069 Fuel Level Sensor B Circuit Intermittent
Could this two fault codes possibly be becouse the workshop took the bumper down or is it something else?
I hope someone can help me with this issue.
Best regards
Energiiz
Old 04-24-2015, 09:35 PM
abcut973's Avatar
'12 C63 Black Series, '12 ML350 BlueTech
Did they reconnect the ambient temp sensor?
It is located on the lower mesh driver side. It needs to be disconnected when removing the front bumper.
For the fuel level sensor it has nothing to do with the bumper. That the sensor that tells you how much gas you have left in the tank. I don't know its exact location but should be closer to the tank than the bumper. Probably underneath the rear bench
Quick Reply: C63 W204 Faultcodes P0073 and P2069
