Lower door Lights
Lower door Lights
Hi Guys,
I have a 2013 C63 (W204) and the lower door lights do not illuminate, no wirring I guess.
I am thinking of wiring them, buying led lamps obviously, where is the best place to pick up the illumination wiring? Is there a control module I can go to or piggy back off the seat adjustment switch illumination?
I have a 2012 coupe. There is a red plastic lens on both doors but nothing lights up when the door is opened. I've gone into settings and tried turning the "surround" lighting on and off, but still no lighting on the doors.
Do we have any 2012+ cars out there with lights?
W204 C63 AMG, W212 E250 CGI, C207 E250 CGI
that red light is to warn others that the door is ajar, at the same time has a light pointed down the floor as a courtesy light for when you go in and out of the car. you wont see this light up at daytime but should be noticeable at night time.
If wanting to convert, I would tie the wire into the door switches. That way they only come on when the doors are open.
For those that do not have these functioning lights, are your cars equipped with the lighting package?
Mine DOES have the lighting package (bi-xenon, etc) but does not have the lower door lights. Mine is a US model, the-big-1 is I think a UK car. Both are 2012+.
Again, are there any 2012+ owners out there that DO have working lower door lights?
how it comes off
Can you explain how you pulled the old reflector lights off. I want to replace mine and I do not want to break them when I take them off Thanks.
