C63 AMG (W204) 2008 - 2015
W204 Coupe with Panoramic Roof Rattles
Old 05-22-2015, 07:27 PM
Bazman's Avatar
2013 AMG C63 Coupe 507
Well it came to me with only 2k km and tight as a nut. After several closed road targa events and the odd track day - it now has some annoying rattles and squeaks. No surprises as it can't be as solid as a steel roof, but.....
Anyone else had experience fixing these? I suspect main culprit is the dividing bridge between front and rear roof glass. Not sure who to go to
Old 05-22-2015, 07:52 PM
Mort's Avatar
Do you think silicone on the seals and a film of grease on the rails will do any good?
Old 05-22-2015, 08:01 PM
Bazman's Avatar
At this point I'll try anything. Will suggest to my tuner as he has it now for servicing post race.
Old 05-23-2015, 08:56 AM
zcct04's Avatar
C63 coupe, Z3M Roadster garage queen
I have the same rattle, and also get a frightening-sounding SNAP from the rear of the pano when the chassis twists (starting up a ramp diagonally so that one wheel starts to rise before the rest). I've got an appointment at the dealer on Monday, will post if they find anything.
Old 05-25-2015, 01:46 AM
deanmc's Avatar
2012 C63 Coupe
I had the loud pop going up driveways as well. Had it fixed by dealer under warranty, it's a known issue with the pano roofs. However, the creaking and rattles are coming back, so I'll have to bring it back before my warranty expires.
Old 05-25-2015, 10:14 AM
zcct04's Avatar
I'm glad to hear that it is fixable. Do you know what they did to it?
Old 05-25-2015, 11:31 AM
abcut973's Avatar
'12 C63 Black Series, '12 ML350 BlueTech
Yep definitely something you'll have to live with!
I got scared the first time. But now I'm getting used to it.
Will probably ask the dealer to fix it at my next service under warranty. But I don't expect any long term solution.
Old 05-25-2015, 11:49 AM
scc2687's Avatar
c43 w205
I saw the service schedule on MB's website that lube and tight the roof is required if you reach 30000km. I went to the dealer two weeks ago and did this service, rattle noise is sitll there, but do improved, less chance to hear it and not that louder compare with before.
Old 05-25-2015, 09:20 PM
KIS007's Avatar
2014 C63 Coupe
Had it in for warranty repair twice to address noise from the pano roof. The second time in, they kept the car 2 days and removed then re-installed the pano roof. Problem was resolved for approximately 6 months. It is back and I've given up.
Old 05-29-2015, 01:54 PM
zcct04's Avatar
For the rattle, service report says "R&R sunshade partition assembly and applied felt tape. Test drove & noise went away."
For the pop, service report says "R&R complete headliner assembly, tighten all screws on pano roof assembly, test drove, all noises went away."
I'll follow up if it's not fixed, but there were no rattles and no pops in the drive back from the dealership.
Old 06-17-2016, 02:21 PM
zcct04's Avatar
Update - one year later and pano on my coupe is still quiet!
Old 06-17-2016, 03:40 PM
Savage-wp's Avatar
2014 Mercedes C63 AMG 507 Edition
That is good to hear.
Mine has the loud popping noise and is due for a service shortly. I think I will ask the dealer to have a look. Based on your report, it sounds like they have to remove the roof liner. This makes me a bit nervous. They could possibly break clips etc on the roof liner. Hopefully being the agents they would do it right.
Old 04-12-2017, 08:57 AM
zcct04's Avatar
It's now been almost 2 years, and I've had no pops or rattles from the sunroof.
Quick Reply: W204 Coupe with Panoramic Roof Rattles
