C63 AMG (W204) 2008 - 2015
Tire pressure.
Old 05-26-2015, 12:10 PM
Bigtickets's Avatar
E55K, Black on Black. C63, Black on Black. SRT-10 NightRunner 363of400
Tire pressure.
Fellas,
What tire pressures are you guys running at the road course track? What's your set up?
Old 05-27-2015, 08:09 AM
BLKROKT's Avatar
Received 2,809 Likes on 1,664 Posts
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
38F 37R is what the Longacre Pyrometer told me
Running Michelin PSS 245/35/19F and 275/30/19R
Old 05-27-2015, 06:27 PM
Diabolis's Avatar
W204 C63 Coupe, W166 ML350 BlueTEC, 928GT, C5 Z06 & IS300 race cars, EQE 4Matic+ on order
On the C63 coupe - my street car - I found that the R888s really come into their own at higher pressures that any other R-comp I've ever used on my P-cars of comparable weight (RA1s liked about 40 psi hot, Michelin PSC and Hoosier R6s another 2-3 psi lower that that). At ~38 psi hot the R888s felt quite loose and I ended up scalloping the fronts. On a suggestion from someone else running R888s on a 997 TT, I upped the pressures to about 40 psi cold (which resulted in about 48F / 46R hot) and they felt a tad more sliuppery than the RA1s but definitley a huge improvement over how they felt earlier. Let out about 3 psi on all four corners and was then running 44-45F / 42-43R hot (pressure indicated by the on-board TPMS during the actual run - not after the coold-down lap), which I found to be the sweet spot and they hooked up at least as good as the RA1s on my Porsche.
As a general rule, suggested pressure for Toyo R-comps on a track-driven street car is 40-43psi hot. Toyo has also indicated that he R888s like higher pressures and lower camber than the RA-1s (they sponsor CASC-OR so one of their guys is usually there at most events), so this also seems to be in line with what he said. The sidewalls are quite stiff so you don't need to worry about rolling them over (like the Michelin PSCs) with street camber.
Good luck - and let me know what you find out. If they seem too loose or squirmy, up the pressurees to 40 psi cold, see how they feel (they'll go up by 6-8 psi hot) and then you can fine-tune it from there.
Old 05-27-2015, 07:13 PM
SPONSOR
PelicanParts.com's Avatar
It does vary between what track you're running at as well. Some left handers or right hander friendly tracks will vary what pressures you run for each tire. Even type of tires vary as well. Nitto NT05's I typically just run around 35-38psi hot.
-Luccia
Old 05-28-2015, 02:21 AM
Case1906's Avatar
AMG GTBS, AMG GTR Pro, AMG GT, C63 AMG, Porsche Panamera 4S, RX-7 FC Turbo II
I run R888s as well and my car seems to like 42-44 psi. I usually start cold at 34-35.
Old 10-01-2019, 12:12 PM
abashoe's Avatar
2007 BMW Z4 MCoupe
Bumping this back up. Did an event yesterday and was playing with pressures. I run Michelin PSS. I was playing with 41-44 hot and was happy with how the car felt. I ran out of time and didnt get to try lower.
Anyone have experience with 37,38,39 psi on a streetable summer tire?
al
Old 10-01-2019, 12:50 PM
BLKROKT's Avatar
Old 10-01-2019, 01:16 PM
abashoe's Avatar
2007 BMW Z4 MCoupe
Perfect. Saw that, but I know you've become quite the track monster in the past couple years so wasnt sure if it still applied. I know you've since been running rcomps.
Will def try these next time around. Thanks!
Old 10-01-2019, 03:44 PM
BLKROKT's Avatar
I think the sweet spot is probably right around 40 cold for PSS/PS4. A psi or two either way is just rounding.
Old 10-01-2019, 04:48 PM
abashoe's Avatar
2007 BMW Z4 MCoupe
I didnt realize you were referring to cold pressures. Thanks for clarifying. What were your hot? 44?
Old 10-01-2019, 06:59 PM
BLKROKT's Avatar
Sorry you’re right. I was thinking about the higher pressure I run the PSC2’s at.
Also my first post above was referring to cold spring temps at WGI. In the summer you’re going to want to run higher pressures probably.
Quick Reply: Tire pressure.
