C63 AMG (W204) 2008 - 2015
Dreaded M156 tappet tick??
Old 06-01-2015, 08:39 AM
ferrariyellow44's Avatar
2012 C63 AMG edition 1
Hey guys,
My M156 is in a W211 but I figured the W204 forums get more action so I'd post it here. Anyway, I think I may have the dreaded tappet tick issue that has turned up on a lot of these engines. I believe its only on the right cylinder bank. Here's the link to the youtube video if you wouldn't mind listening to it and letting me know your opinion:
Let me know how bad you think it is and how urgently I need to replace the tappets and cam. I really don't want it to bust a whole in the tappet and ruin this engine...its spectacular!
Anybody get MBUSA to cover the work??
Old 06-01-2015, 10:53 AM
Valvestud's Avatar
2014 E63 AMGs, 2015 F-150 Lariat, 2010 Porsche C4S
Originally Posted by ferrariyellow44
Hey guys,
W211 E63 M156 engine tick - YouTube
Does it go away once warmed up, and what oil are you using?
Old 06-01-2015, 11:29 AM
I took that video with it at operating temp, 81 degrees C.
I've always used Mobil 1 0w-40. Thats the right stuff? I know Merc says to now use a 5w-40 but that only changes the winter viscosity...
Old 06-01-2015, 12:15 PM
HBC350's Avatar
'18 C63A Cabriolet
Hey guys,
Mine has done that once. And I took it for a drive and it went away and has never come back. Is yours now constant? If so, take it in asap.
If not, at a minimum, I'd bring it to the dealer and complain about it so that you have it on record. Not sure where you are but in CA, if a defect manifests itself during the warranty period, the warranty does not expire until the defect is fixed. That language is on the reverse side of every repair invoice the dealer gives you.
Edit: You are on LI (I'm a Smithtown native!) and NY likely has the same basic warranty law.
Old 06-01-2015, 12:53 PM
AMGonFire's Avatar
2012 c63 AMG, 2011 GLK 350, 2019 GLS 450
If it's constant for extended time period I'm going with cam adjusters. What year is your car? Google cam adjusters there are a couple videos but sound always comes from the drivers side for some reason. Do you have a rattle sound from that area on startup?
Old 06-01-2015, 03:17 PM
rentzington's Avatar
2010 C63 P30
If it's just during warmup I wouldn't be too worried about it as it's just not fully lubricated yet...if it's constant or does it when warm I'd get the cams and valve buckets checked
Old 06-01-2015, 05:27 PM
Nice! I'm in Dix Hills.
I'm out of warranty at this point (probably a mistake) but I called MBUSA earlier today so at least its documented. Apparently they haven't settled the lawsuit over the issue (?) If its settled, at least I'm documented and could have something re-reimbursed.
Old 06-01-2015, 05:29 PM
The sound is constant even after warm up. Whats the story with the cam adjusters? It is only on the drivers side. Are they defective and often need replacing? or are they just typically noisy and theres nothing to worry about?
Old 06-02-2015, 12:01 AM
layzie12g's Avatar
2008 Mercedes Benz E63
I work at a dealer and we had an E63 come in with a very similar noise. There is a bulletin out that calls for replacement of camshafts and tappets. $6,000+ in parts alone. After this was done the noise was gone. If it was my car I would do lifters alone. I'm assuming they want the cams and tappets to wear to each other, but at that cost I would take my chances.
There was no noticeable wear on the cams or tappets. The test to see if they need to be replaced is to push on the lifter and see if they feel "soft". In my opinion it was not the best wording. Using a brass punch and arm pressure you could feel some of the tappets give under pressure.
Old 06-02-2015, 02:06 AM
Merc63's Avatar
C63 AMG
Is try new cam adjusters first
Old 06-02-2015, 08:23 AM
Yeah I guess I'll pull the valve covers off and try this test, I'm not sure exactly what "soft" means but maybe I'll notice it on only certain tappets. I just hope to god the cams are fine!
This really blows my mind that Mercedes isn't fixing this. Its a pretty incredibly devastating issue for the engine considering it only has 58K on it!! @layzie12G Did that owner of the E63 you worked on get his cams and tappets replaced at cost? or did Mercedes pick up some of the costs?
Old 06-02-2015, 10:02 AM
layzie12g's Avatar
Actually Benz did pick up all of the cost. I guess the car has had various engine issues since it was new. That is the only reason. If you car has been healthy up until now, I would assume your on your own.
Old 06-02-2015, 12:29 PM
Jeeze, well that sucks. I think it'll make more sense for me to just trade this thing in...
Old 06-02-2015, 12:49 PM
jvanbrecht's Avatar
2017 Mini Cooper S Clubman ALL4 - British Racing Green
The lawsuit you are referring to was dismissed, no settlement, I cannot remember the details.
My car also has the ticking, and a slight high pitched rattling has developed which is a little worrying, but I am at 110k miles and almost a year out of warranty. Not sure what I am going to do.
Old 06-02-2015, 02:08 PM
Yeah I'm getting out of this thing. Its a shame, such an incredible engine. It just doesn't make much sense to spend $6k on a car thats worth $28k, I'll just trade it in at $23k and consider myself lucky!
Old 06-04-2015, 10:13 PM
sinape62's Avatar
2013 C63 Coupe
Mine started tapping today, but I haven't driven or started it for almost two weeks.
This happened when it was sitting for nearly two months last year when I traveled a lot.
Old 06-05-2015, 09:45 AM
I think that's a different issue. Apparently when they sit for awhile they just need oil to circulate, apparently the engine has drainage issues or something. My problem is persistent whether it sits for awhile or not
Old 06-05-2015, 04:43 PM
Spearsba's Avatar
2011 C63 P31, 2012 ML350, 2007 335i E93
My 2011 had the nasty ticking. It was under warranty as a CPO. The dealer tried twice with the lifters, cam shaft etc, no luck still ticked. I ended up with a new M156 freshly shipped from Afalterbach.
Old 06-06-2015, 10:51 AM
kamalpatel12448's Avatar
W202 (1999 C240) and W204 (2008 C63)
If it has been sitting, does it and then goes away after warming up I would not worry, but if it is a regular and persistent problem then would suggest having it diagnosed and repaired. Need good techs to do this.
Old 06-07-2015, 06:20 PM
Yeah I'm just dumping the car. I have no interest in spending $6k for new tappets and cams...too bad though, absolutely loved this car!
Old 06-07-2015, 07:45 PM
layzie12g's Avatar
Shop around. Labor time is only 6 hours to do the job. I would just replace the lifters if it was me.
Old 06-07-2015, 08:22 PM
solekeeper's Avatar
A V8
mine makes an intermittent tamping... it's totally random. dealer checked it, said it was fine.
do you have the SB for this?
Old 06-07-2015, 08:40 PM
layzie12g's Avatar
I do not.
Old 06-07-2015, 09:31 PM
solekeeper's Avatar
A V8
I do not.
i'll keep an eye on the car... it's already logged into the system about the ticking. so i guess if the engine blows, they'll just have to get me another one.
Quick Reply: Dreaded M156 tappet tick??
