Tyre size question
Tyre size question
Apologies if this has been asked before but I can't seem to find a definitive answer.
I have 19" multi spoke alloys on a 2012 coupe.
Currently running 255/30/19. Can I safely fit 275/30/19 without any rubbing. I have no intentions of lowering the car but I do want to fit spacers to get a more flush look.
Many thanks in advance.
W204 C63 Coupe, W166 ML350 BlueTEC, 928GT, C5 Z06 & IS300 race cars, EQE 4Matic+ on order
While it will physically fit, a 275 size tire is a tad on the wide side for a 9" rim so it's not going to be the best fit visually, and furthermore, the tire will tend to somewhat "squirm" sideways during cornering because of the narrower rim so any potential benefit from the wider contact patch will likely be offset by slightly worse cornering stability. On the other hand, if straight line traction is all you have in mind, it will likely work just fine and (all other things being equal) you will get a bit more grip.
With 275 sized tire on the OEM rear rims, putting spacers on the back is IMHO not a viable option as it will very likely rub against the fender.
I don't know about the 19s but for the 18s I actually just got off the phone with my tire guy:
I am putting
245/40/18 on the fronts
265/35/18 on the rears.
Michelin Pilot Sport AS/3
Great tire! Lasted me 2 years and 12,000 miles vs the original Conti that lasted 1 year and 8,000 miles. Not to mention a lot better ride and grip.
I am putting
I don't know about the 19s but for the 18s I actually just got off the phone with my tire guy: I am putting 245/40/18 on the fronts 265/35/18 on the rears. Michelin Pilot Sport AS/3 Great tire! Lasted me 2 years and 12,000 miles vs the original Conti that lasted 1 year and 8,000 miles. Not to mention a lot better ride and grip.
Wheel / tire size / offset comparison app:
http://www.rimsntires.com/specspro.jsp
Going from 255/30-19 to 275/30-19 results in a 1.8% speedo difference.
