AC problems on my C63 are driving me nuts
2011 C63 2013 GTR
Hello and good day everyone!
If you don't wanna read the fu
I recently bought a 2011, 20k miles W204 C63 that was previously a friend's car. The purpose is to have a fun DD which I hope wasn't a big mistake
The car is clean all around, facelifted to 2012+, P31, and some CF goodies! Just the was I would have ordered it!
AC started acting up soon after I got the car, warm air, and I notice the condenser or radiator fan seem to be on more than normal (and more noisy too)
Took the car to a Mercedes shop (not a dealer)
It was determined that the AC compressor is gone (which is weird at such a low mileage, but they should know better than I do)
Replaced the compressor with a brand new one, cleaned the system, replaced the filter and all was working fine for a couple of days!
3 days later, the AC went back to blowing warm air
warmer in the passenger side compared to the driver side, but both sides are warm. There was also a hissing noise coming from behind the dashboard, I wanna say behind the driver's side vent
They found 2 small leaks, fixed them, tested the pressure, charged the system, and it is still warm
They told me now that it must be a "clogged condenser", so they are replacing that too
It's taking far too long, and I'm sure by now that they are guessing
I booked an appointment on 7/7 with the dealer which is both incompetent and overpriced IMO, but I just want the headache to be over!
Anyone here had the same issue and can share where to look or what to look for, temperatures are insane here and I could really use the AC
-AJ
-AJ
2011 C63 2013 GTR
Received 2,810 Likes
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Sounds like they are properly narrowing down what the problem might be. I don't know what else you expect them to do, that's how you fix problems. It's just AC man, get a grip. It'll get fixed. I'd ask your friend what's up, because he probably knows.
2011 C63 2013 GTR
I was hoping to see if someone else had the same symptoms and was able to find where the problem is, or if there is a part that is known to fail. That's the main purpose of this thread
I bought the car used, as is from my friend, so not blaming him for this, but the failure is most likely caused by flooring the car a lot with the AC on
The car keeps switching the compressor on and off and will eventually cause a failure
My only hope is it won't be something electrical that will keep blowing parts (and my money) left and right!
-AJ
Ok.... well I'd be pretty frikin aggravated if it was 122 and no AC too. Holy ****. Good luck on the fix.
Do you understand how AC works? Because that's actually nothing like AC, unless yours blows 122deg ambient temp air around. Because that's all your suggestion does..
What did they use to fix the leaks? Did they replace or remove the lines and fix them or did they charge the system with R-134a that has sealant in it?
2009 C63
i had a similar issue but i also had a CEL for ambient air sensor. i'm not sure if it was placebo or not but right after i had the ambient air sensor replaced my AC was blowing cold air again.
is the car reading temp correctly?
2011 C63 2013 GTR
The AC seems to be working great, but I'll give it at least a couple of weeks of regular use before I can judge
I didn't notice the ambient temp readings before to be honest, the exhaust note was distracting me
Thank you for the help, and I hope this will be the end of my AC troubles (for now at least), but I will keep this thread updated!
-AJ
2011 C63 2013 GTR
So I picked up the car last night and the AC is blowing cold air, hoping this will not change!
Today, I had the AC on full blast in the afternoon, and noticed the air is cold, but it's not blowing nearly hard enough. it doesn't reach the body or face of the driver
Speculations:
Duct work came loose somewhere
Blockage somewhere in the system
Any other thoughts?
-AJ
Speculations:
Any other thoughts?
-AJ
