Squeak at upshift
Squeak at upshift
So my 507 is past 1200 miles and I'm easing into hard driving. Now that I've put it in sport+ ,automatic, and floored it and let it shift on its own, at redline, I'm noticing a loud "squeak" or "chirp" sound.
It will happen if the throttle is floored and the car shifts at redline. I cannot figure out what the noise is though or determine if it's normal.
It seems to happen most when the car shifts hard or jerks so I was thinking maybe suspension squeak of motor moving. That didn't seem plausible though. Then I thought maybe it's a second and third gear split second peel out, tires chirping, causing the jerk etc.
Does anyone know what I'm hearing???
My car drives awesome, so I'm hoping it's a normal sound.
The following 2 users liked this post by guynamedsean:
Joel Salinas (05-14-2021),
PP-PRO_C63 (08-27-2023)
My guess would be tires. Just keep an eye on it but as long as you have no CELs you're going to be set.
Forgot to check back with you guys after my drive home. If you turn down the radio, make sure the air conditioner isn't blasting and really pay attention you can actually hear it on every up-shift at wide open throttle. Not really that noticeable unless you are really listening for it.
Good to know that it is normal, I figured it had something to do with the wet clutch system
i have this problem too! I believe that this is not normal! Here's my post...
https://mbworld.org/forums/c63-amg-w...ml#post6509030
Received 1,884 Likes
2014 E63S; AMS 100 octane ecu tune; edok tcu tune; BB intakes; dyno tuned
I don't have this noise ... Mct transmission here
Did anyone figure out what the sound was or if its normal or an issue? my 2018 C63s is doing this in 3rd as well a buddies 2016 c63s. different platform I know but same sound so very interesting to stumble upon this with W204 owners.
