2012 C63 Steering column on 2010 possible?
Out of curiosity gents, would I be able to bolt in the steering column and face lift steering wheel into my 2010?
I know that Anthony swapped over the E class column successfully to his PFL car.
I would assume it should be a direct bolt on. But from my research I couldn't find anyone who has done a 2012 C63 Column into a 2010.
Any helps appreciated.
Yes, I'm pretty sure this is possible. I thought about updating my 2012 E to swap the turn signal/cruise control positions as I prefer the 2014+ arrangement. From my research you need to make sure what you get is correct for the options you have (eg. blind spot land tracking assist, heated steering wheel, etc.)
