Compression test DIY?
Hi Folks,
I am about to change my plugs so I thought I would do a compression test while I am at it. Are there an MB WIS docs on this. I just don't want to confuse the ECU when I am cranking.
Essentially trying to crank without ignition or spark without triggering an alarm. Couple of fuses maybe or does MB have some more elegant form of diagnostic mode?
it's very accurate in comparing one to another. the values it gives you are difference in rpm though not compression. There really is no need to check compression if everything is running fine. Typically unless you are getting a misfire or drivability problems your compression is fine. These cars are very very picky.
