C63 AMG (W204) 2008 - 2015
245/275 on OEM 19" Multispoke
Old 09-14-2015, 10:19 PM
Phil Chow's Avatar
W204 C63
Anybody run this combo?
I know the OEM Multispokes are 19x8/19x9.
I'm looking to grab new wheels, but they wont' be here for a while, and my tires are on their way out. Would swap these over to my new wheels after, which will be specced to 19x9/19x10, which I know the 247/275 combo will work.
Anybody have any photos of them running 247/275 on 19" Multispokes?
Preferably with Michelin PSS, but I'll take photos of anyhting! Just want to know if they look weird and really bulgey.
Old 09-14-2015, 10:43 PM
CGK
CGK's Avatar
C63
I am running 235/35/19 front and 275/30/19 rear. Michelin PSS. Ill get some photos to you soon.
Old 09-15-2015, 06:58 PM
Carbon Dated's Avatar
2019 GLE 63S AMG, 2009 C63
I am running the 245/275 combo on stock 19's. There is NO bulge or anything weird looking about them that I can see. They seem to fit perfectly.
Old 09-15-2015, 10:11 PM
Phil Chow's Avatar
W204 C63
Thank You! Waiting for photos! Any spacers on that fitment?
Phil Chow's Avatar
W204 C63
Any photos? You lowered and any spacers?
Old 09-16-2015, 01:10 AM
charliekay's Avatar
C63 AMG
Pics as promised.
The rubber is 2 days and less than 100km old, so this is what they will look like with no wear.
235/35/19 Michelin PSS front
275/30/19 Michelin PSS rear
Current stance with H&R Springs w/ OEM 19s, Michelin PSS all round. 235s front and 275s rear.
Old 09-16-2015, 02:09 AM
Phil Chow's Avatar
W204 C63
That actually looks perfect! Very nice to see there's literally no bulging at all. I would've expected it to bulge a little bit.
You dont' happen to have spacers at all or anything do you? Any reason why you didn't size up to a 245/35/19 in the front also?
Old 09-16-2015, 02:35 AM
charliekay's Avatar
C63 AMG
No spacers. If you put spacers on the rear it will rub. Front with 12mm spacers will be fine.
If you put 10mm spacers on the back with 255s it will be fine, spacers on the rear with 275s and you will rub.
Recommended setup with spacers is 12mm spacers front with 235s, and 10mm spacers rear with 255s. 265s work with the 10mm spacers but it comes down to what brand tires you, as some 265s run wider than others.
Remember my setup is with H&R springs, that isn't stock height.
I have spacers, brand new unused and was going to put them on but my car is modified and running 550+hp to the rear wheels. Wider rubber to get more traction was more important than stance to me.
Old 09-16-2015, 02:50 AM
Phil Chow's Avatar
W204 C63
Perfect! I've got KW DDCs on the way, so I can set them to whatever height I so choose.
Maybe I won't even need the 12MM Spacers with the 245s, though, I reckon it could still use a 5MM.
I'd only be getting Michelin PSS, nothing else really.
Old 09-18-2015, 11:26 PM
Phil Chow's Avatar
W204 C63
Anybody else able to chime in?
Old 09-19-2015, 02:53 AM
dchl21's Avatar
Gallado Spyder / AMG C63S / Cayenne
235 265 with 12mm spacers all around. perfect.
I had 275 with 12mm rubs slightly. p30 oem lower
Old 09-25-2015, 08:06 PM
medamullet's Avatar
2011 C63 AMG
I want those wheels.
Old 09-26-2015, 02:23 PM
I am Jeff's Avatar
Steel Grey Metallic C63!!
Ask member DanishAli. I just sold him my set of multispokes with Michelin PSS 245/275 tires. It looks gorgeous on his C63 coupe.
Old 09-27-2015, 08:40 AM
yellows2k's Avatar
so 245 fronts wont work?
im looking at some new rubber soon. im deciding on 265 or 275 rears. seems like 275 is easily achieved
Old 09-27-2015, 09:42 AM
Phil Chow's Avatar
W204 C63
From what I gather, 245 fronts will work perfectly fine. Might actually even be able to run a small spacer depending on how low/high you are
Old 10-29-2015, 06:02 AM
medamullet's Avatar
2011 C63 AMG
H&R
With your H&R springs did you use the stock 13mm pads? It looks pretty level with the wheel gap font and rear.
Old 03-10-2016, 11:01 PM
GQsmooth's Avatar
ML
Bump, anyone have a pic of stock height with 245/275 PSS setup?
Old 03-11-2016, 08:09 AM
not PSS but...19"AMG wheels and stock suspension.
need2speed (03-11-2016)
Old 05-15-2018, 01:19 AM
ShaneN.'s Avatar
2018 e63s edition 1
Bumping an old thread because I need new tires. Thinking of going PSS 245/265 or maybe 275 - stock 19.
The car has some sort of conti (stock?) 235 on it now in the front with PSS 265 in rear. Going with a 245 PSS in front now, will I notice any positive difference in handling? Any less understeer with a wider tire?
So I'd need to order: 245/35/19 and 265 or 275/30/19, right? I don't understand the different aspect ratio.
edit: I just discovered there is a pss replacement when looking through the forum. I might go ps4 but same questions still apply. I assume they'd fit exactly the same.
Old 05-15-2018, 06:11 AM
rene_gts's Avatar
I'm running 245/35/19 and 275/30/19 PS4S on my stock 19" multispoke wheels, the car is not lowered and they fit just fine. Also no spacers.
Old 05-15-2018, 12:15 PM
m a x i m u s's Avatar
C63 AMG P30 *EuroCharged*| Porsche Cayenne | Buell XB9SX
Shane: the aspect ratio number represents the height of the sidewall as a % of the width. That's why the 275 width is 30(%) and the 245 is 35(%).
Old 05-17-2018, 04:17 AM
ShaneN.'s Avatar
2018 e63s edition 1
I actually feel somewhat embarrassed that I never clued into the "ratio" part of it. I always just thought of it as a measurement, like 30 would be shorter sidewall than 35. This is also making me realize I probably can't replace my bald front tires with new 245/35 until my 265/30 rears are cooked off?
Exactly what I wanted to hear. I'm going to go that exact same tire+size on my exact same car. I'm sure that setup would still work with some H&R springs too.
Quick Reply: 245/275 on OEM 19" Multispoke
