C63 AMG (W204) 2008 - 2015
Wheels bolt pattern & Offset (2010 SLK55 vs. 2010 C63)
Old 10-02-2015, 11:54 AM
cooperlee's Avatar
C63
Question Wheels bolt pattern & Offset (2010 SLK55 vs. 2010 C63)
Does anyone know if the wheels from a SLK55 would fit on a C63? Thinking to swap OEM wheels/tires between both cars. Thx
Old 10-02-2015, 12:10 PM
Conv_GSDriver's Avatar
'18 Audi A4
the PCD (bolt pattern) for the SLK 55 is 5x112 which is the same as the C63 along with the 66.6 bore size, same as the C63. As far as the offset and will it fit on the C63, not sure, just do the test fit. The C63 usually has a high offset wheel from factory, around +40 for fronts and +45 for rears. The SLK OEM wheel I think is +35?
Old 10-02-2015, 04:32 PM
Mort's Avatar
OEM C63 is ET +45 front; ET + 54 rear.
Old 10-05-2015, 06:58 AM
'18 Audi A4
Yes thanks for the correction.
Quick Reply: Wheels bolt pattern & Offset (2010 SLK55 vs. 2010 C63)
